Subject Topic: transmission filters Post ReplyPost New Topic
scottflys2
Posted: December 30 2010 at 02:28 | IP Logged Quote scottflys2
  The boat yard serviced my transmissions but it appears they put the wrong gaskets in.  Transmission oil is leaking on the side of the filter housing where it seals on the filter housing.  I removed same and found a flat gasket about 5/8 inch wide I think this is wrong should be a 1/4 inch square gasket which comes with the filter.  any help  don't have drawing of this filter  sk
Gemba
Back to Top Printable version View scottflys2's Profile Search for other posts by scottflys2
