Subject Topic: fuel guages Post ReplyPost New Topic
scottflys2
Posted: September 07 2010 at 17:09 | IP Logged Quote scottflys2
Anybody know the resistance value of the fuel guages on the 500.  They are VDO guages and I want to convert the senders from the float type to electronic.  It wpuld be for the saddle tanks as the people who polished my fuel destroyed the floats.  Thanks in advance.
Gemba
Back to Top Printable version View scottflys2's Profile Search for other posts by scottflys2
Pete37
Posted: November 07 2010 at 19:09 | IP Logged Quote Pete37
Hi Scottflys,
This is a rather old post so you probably already have the answer.  I'm not sure what you mean by a 500.  If it's a Constellation 500 the fuel gauge could be either a US or VDO type.  The former has a range of 240-33 ohms while the latter has a range of 10-180 ohms.  I haven't checked the fuel gauges but the temperature gauge is a US type so the fuel gauges probably are too.  You need to find the type number which should be 301-505 or 301-506 for the US gauge.  The VDO gauge would be  or 301-501 or 301-502.
The Constellation 500 has a very messy fuel gauge system because it has four tanks and uses different readout systems on the lower console and FB.  If you can't find the gauge numbers on your boat let me know.  I may be able to find them on mine.  Answer on the Constellation 500 site.
Pete37
INTERLUDE
scottflys2
Posted: November 08 2010 at 12:46 | IP Logged Quote scottflys2
Thanks Pete
Got some senders from a guy in fl he makes them all are working great
Gemba
This page was generated in 1.5313 seconds.
