Wellcraft
Subject Topic: Wellcraft Maerinique 2600 and Excel 26SE Post ReplyPost New Topic
siffrin
Posted: March 16 2010 at 18:29 | IP Logged Quote siffrin
I  have seen a problem on both a 1999 Matinique 2600 and an 1997 Excel 26SE.
In both cases the wood encapulated barrier between the engine and the fuel tank was cracked. In the Martinique the surveyor felt that while he believed the boat had not sunk he did fell the engine compartment had taken on a fair amount of water and caused that barrier to split and then rot. in the Excel and barrier was split but a quick knife test did not show any softness.
Has anyone else seen this problem and any solution short of pullling the engine etc.
Back to Top Printable version View siffrin's Profile Search for other posts by siffrin
This page was generated in 1.1084 seconds.
