Albin
 BoatUS Boat Groups/Manufacturer Forums>>Albin
Subject Topic: Upgrades for any Marine Diesel Post ReplyPost New Topic
PeninsularEngines
Posted: November 03 2009 at 13:56 | IP Logged Quote PeninsularEngines
Hello.
We have a couple of upgade kits that we'd like to make you aware of. These are "system" type upgrade kits that will work on ANY diesel marine engine and not specific to Peninsular. Additional information and pricing can be found on the Parts OnLine page at www.PeninsularDiesel.com
Fuel Pump Upgrade Kit.
For those of you who have a difficult time starting your diesel engine after changing fuel filters, this upgrade kit is an Racor 900 - 12Volt electric fuel pump with water separator and check valve. It comes with brass Tee's and formed hoses and is assembled on an aluminum plate for easy installation. This upgrade kit will extend your battery and starter life by eliminating long cranking sessions and will eliminate the need for you to "crack" injectors or fuel lines to vent air.
Glow Plug Timer Upgrade Kit
This upgrade kit will give you quicker starts and less smoke on cold starts. It includes an improved adjustable timer, solenoid, a manual override switch, instructions, and wiring diagram. This kit will give you quicker and adjustable glow time and the manual control switch can be used for warm starts.
If you have any questions about these kits, post a message here and I'll be happy to answer them.
Thanks,
Bert DeVries
Peninsular Engines, Inc.
Bert DeVries
Bert@PeninsularDiesel.com
Back to Top Printable version View PeninsularEngines's Profile Search for other posts by PeninsularEngines
