Sea-Pro
 BoatUS Boat Groups/Manufacturer Forums>>Sea-Pro
Subject Topic: Fuel tank Post ReplyPost New Topic
eyes183
Posted: September 07 2009 at 17:01 | IP Logged Quote eyes183
I just picked up a 1997 190 wa sea pro/ with a 115 johnson. I'm trying to find out what size fuel tank is on the boat, but having difficulty getting any info. If anybody could tell me it would be helpful. All equipment to the best of my knowlege is original.
Back to Top Printable version View eyes183's Profile Search for other posts by eyes183
CuCountry
Posted: September 07 2009 at 21:34 | IP Logged Quote CuCountry
I have a Sea Pro 238 WA and there is a circular inspection port in the battery box under the aft seat. If you open this port you can view the fuel tank nameplate as well as inspecting the fittings and fuel lines leading to the Outboard engine. I don't know if your boat has the same set-up but I would think that it would be similar.
Copper Country
Back to Top Printable version View CuCountry's Profile Search for other posts by CuCountry
eyes183
Posted: September 08 2009 at 18:02 | IP Logged Quote eyes183
My inspection port is located in the middle of the deck, but thanks for the tip I'll check around in that area.
eyes183
Posted: May 26 2010 at 20:41 | IP Logged Quote eyes183
unfortunately I still can't find out what size fuel tank my 1997 sea pro 190wa has. I have been to just about every web site, and have checked everywhere on the boat. Including under the deck where the sending unit goes into the tank. I'm at a loss for places to look. Any other ideas would be welcome. Thanks Chris
CuCountry
Posted: May 29 2010 at 23:09 | IP Logged Quote CuCountry
You could make some ballpark measurements of the fuel tank and calculate the volume. My fuel tank is rectangular crossection which I can measure and approximate the length by measurement through a couple of the removable port holes in the deck. Then you could fill your tank, and with a flow measurement device measure the fuel useage until it is almost empty and refill and determine the diffference. Would that be close enogh??
Copper Country
This page was generated in 1.1720 seconds.
