I have a 1985 Chris Craft Constellation with a water leak that has me frustrated. Water is coming in the master stateroon on the starboard side rear corner above the window valence. Water is also wetting the carpet in the second stateroom or office as I call it. The carpet is wet on the staroard rear side of the room. I would welcome any suggestions as to where my water problems are comming.
While I have not had any leaks in the areas that you mentioned, I had a leak in the salon window. I ended up recalking all of the windows with clear silicone on the outside. No more leaks. Of course the aft door still leaks at the bottom when it rains. I keep a small container on the floor for it to drip in. Good luck on clearing up your problem. Check out the Constellation forum. Great people and good information.
__________________ Tony and Vicki
FIVE STAR
1985 Constellation
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot delete your posts in this forum You cannot edit your posts in this forum You cannot create polls in this forum You cannot vote in polls in this forum
