Subject Topic: 290 DA Leaks Post ReplyPost New Topic
tomas
Posted: August 22 2007 at 11:34 | IP Logged Quote tomas
Acquired a 1996 290 Sundancer. I have water in the starboard dinette compartment and in the mid-cabin port(water pump)compartment. Looks like it is comming down the walls????? Anybody know wher the water is coming from and how to fix?
Toby
Back to Top Printable version View tomas's Profile Search for other posts by tomas
Secondbesttoy
Posted: August 22 2007 at 11:37 | IP Logged Quote Secondbesttoy
I have the same question for a 1999 270SDA.  Water on the floor at the steps.
Secondbesttoy
Back to Top Printable version View Secondbesttoy's Profile Search for other posts by Secondbesttoy
Rock Hall
Posted: August 22 2007 at 12:29 | IP Logged Quote Rock Hall
I was getting water on the floor of my main cabin. Took a while to figure out, but I had a slow leak in a fresh water hose. Do you notice your pump running when you are not using any water? This would be a sure sign of a leak somewhere. As the pressure in the system drops, the pump might kick on for only a sec or so to bring it back up to pressure.
Mark
Back to Top Printable version View Rock Hall's Profile Search for other posts by Rock Hall
Secondbesttoy
Posted: August 22 2007 at 14:01 | IP Logged Quote Secondbesttoy
Thanks for the reply.  That was actually the 1st thing I checked.  The water pressure will actually hold for weeks at a time betweem use (and that is a sad thing that it is sometime weeks between use). The floor will get "suddenly" get wet.  I have also re-seaed all the ports and hatches.
guye926
Posted: August 22 2007 at 16:56 | IP Logged Quote guye926
Same issue here with a 2000 270 DA, floor gets wet between bottom right corner of fridge and the door to the head, would love to get help with the mystery!!!
Sweet Emocean II
2000 27' Sea Ray Sundancer
Back to Top Printable version View guye926's Profile Search for other posts by guye926
This page was generated in 1.5508 seconds.
