Bayliner
Subject Topic: Running problems Post ReplyPost New Topic
pgcan
Posted: August 08 2007 at 09:56 | IP Logged Quote pgcan
Good Moring all
Here is my problem i have a 2955 avanti  with 454 i love this boat
but my problem is that she will get up to 4800 rpm and then she will bog down to 3000 rpm and she will jump up and down she wants to go but it like she is being held back,
now i have changed the fuel filter and i have cleaned the carb after i cleaned the carb i took her out and she ran good then 20min later she started doing the same thing again
i dont know what to do  does any one have any ideas
please help
Paul
Back to Top Printable version View pgcan's Profile Search for other posts by pgcan
barneybutler
Posted: August 13 2007 at 15:29 | IP Logged Quote barneybutler
check for water in fuel tank, or a clogged tank vent.
remove the fuel line and pump some gas into a can and see if there are any water bubbles in the bottom.  [water is heaver than gas so it will look like bubbles on the bottom of the bucket] If there is a little water in the tank it might not pick it up until the boat starts bouncing on the waves or tilts to get on a plane.  then the water gets sucked into the fuel line.  If you have an inspection plate remove it and look in the tank for water.  Also look for something clogging the pickup tube in the tank and a clogged vent that lets air into the tank as the fuel goes out.  The fuel vent is usually on the side of the boat high up somewhere.  If you can't find it just disconnect the vent line from the tank and blow air through it to see if it is clear.  [I have seen bugs clog them]
good luck
Barney
barneybutler@hotmail.com
Barney
Back to Top Printable version View barneybutler's Profile Search for other posts by barneybutler
gpreichert
Posted: October 14 2007 at 08:52 | IP Logged Quote gpreichert
It may be as simple as burning high test vs regular. I made that mistake once, motor ran like crap, then put in some octane booster, then next time, filled tank with high test. Not only did the problem go away, never had an issue again.
Gene
_________________________
Work is for people who don't know how to fish
Back to Top Printable version View gpreichert's Profile Search for other posts by gpreichert
