Subject Topic: 2003 Doral 280SE Post ReplyPost New Topic
harald
Posted: July 30 2007 at 16:23 | IP Logged Quote harald
Hi,
  are there any problems with leaking deck to hull joints and stringers, that can lead to waterintrusion with this model, including railings. Anything else I should look out for?  How good is the support of the manufacturer?
John
Back to Top Printable version View harald's Profile Search for other posts by harald
three of a kind
Posted: August 01 2007 at 18:33 | IP Logged Quote three of a kind
we have a 2004 280/prestancia and have had trouble with leaks in the cabin.  SOurces have been found and corrected include:  deck/hull joint, mis-drilled snaps (holding down bow cushion), and water in the railing (source - bad seal at the Nav light).
We now seem to have it reduced to a very slight leak port side bow, just behind the anchor locker, forward of the first port side porthole.  If any forum members have ideas, im all ears. thanks.
Very frustrating.
Doral has been pretty good about it, but it still leaks!
Back to Top Printable version View three of a kind's Profile Search for other posts by three of a kind
This page was generated in 1.3125 seconds.
