Trophy
 BoatUS Boat Groups/Manufacturer Forums>>Trophy
Subject Topic: Trailering a Trophy 1802 Post ReplyPost New Topic
pare1
Posted: July 25 2007 at 18:30 | IP Logged Quote pare1
I'm considering the purchase of a Trophy 1802. My limitation in my tow vehicle is a 2006 Toyota Sienna minivan with a tow limit of 3500 lbs. The 1802 is within that limit, but a friend said that only applies to towing on a roadway. He doesn't think I'll be able to pull the boat out of the water after putting it back on the trailer.
HELP. Does anyone have any experience or thoughts?
Edited by pare1 on July 25 2007 at 18:50
Back to Top Printable version View pare1's Profile Search for other posts by pare1
cormorant71
Posted: August 11 2007 at 11:53 | IP Logged Quote cormorant71
your friend is right. dont try it.  you need to be at most trailering 80% of your vehicals max rating for towing a boat.  also, dont forget about the weight of the gas and gear in the boat and the people in the mini van.  also, if the mini van is front wheel drive you are not going to get traction on a ramp.  i hope this helps, i have been trailering boats for over 15 years, and seen simmilar problems from under powered and FWD cars a lot.
chris
Back to Top Printable version View cormorant71's Profile Search for other posts by cormorant71
This page was generated in 0.8438 seconds.
