Wellcraft
Subject Topic: Gas tank selector switch Post ReplyPost New Topic
1500Driver
Posted: May 19 2007 at 20:48 | IP Logged Quote 1500Driver
This is my first post so please be kind.  I recently purchased a project boat- a 1974 Wellcraft 185.  It has two fuel fills and an on-off-on switch on the dash.  How does this work?  Does the switch actually select a tank to feed the engine? Or does it just select a tank to show fuel quantity in that tank?   Are both tanks feeding the engine at all times?   If not - how do I switch tanks?  Any help will be greatly appreciated.  Thanks,  Ed.
Back to Top Printable version View 1500Driver's Profile Search for other posts by 1500Driver
1500Driver
Posted: May 23 2007 at 17:57 | IP Logged Quote 1500Driver
Four days later- and I can answer my own question.  After removing both rear seats AND the support structure for those seats I was able to use a mirror and search the black hole area above and behind the bilge blower and vent hoses.  There, mounted to the underside of the deck at the transom,are two valves feeding a  "T" which goes right to the fuel pump.  Once you know where they are you only have to remove the port seat back cushion in order to blindly position the valves.  POOR engineering.  For a long time I believed that planes should be designed by the people that have to work on them- OR they should, at least, be consulted!  Now I'll extend that to boats, too.  Thanks, this problem solved.  Ed.
This page was generated in 0.9072 seconds.
