Bayliner
Subject Topic: Neutra Salt System Post ReplyPost New Topic
Jamato
Posted: January 28 2007 at 21:29 | IP Logged Quote Jamato
I just purchased an 02 Bayliner 2452 with the 5.7 B2 engine which has 50 hours on it. I'm going to install the NeutraSalt System by Volvo as it will be used in salt water here on the Gulf. Appreciate hearing from anyone who has installed this system.
Thanks,
Paul
Englewood, FL
Paul
Bayliner 2452
Englewood, FL
Back to Top Printable version View Jamato's Profile Search for other posts by Jamato
Cabin Fever
Posted: April 19 2007 at 14:09 | IP Logged Quote Cabin Fever
Paul,
Good luck on the Neutrasalt.... my 05 2465 Regal 5.0 OSI Volvo just had to have replacement manifolds and risers with 84 hours and less than two years on engine. Boat came with the system, I used the system after every time. The boat is kept on a trailer and out of Gulf waters. I had the freshwater flush extended to transom and will never use Neutrasalt again.
Tom
Naples Fl.
Back to Top Printable version View Cabin Fever's Profile Search for other posts by Cabin Fever
Jamato
Posted: April 19 2007 at 16:36 | IP Logged Quote Jamato
Wow. Not exactly a ringing endorsement  Tom.  Did you contact Volvo about your bad experience? If so, what did they say?  Did  you have the system installed ?
Thanks for your reply
Paul
Bayliner 2452
Englewood, FL
This page was generated in 1.3906 seconds.
