Subject Topic: Water Leak Post ReplyPost New Topic
jowick
Posted: August 30 2006 at 17:24 | IP Logged Quote jowick
I have a 1988 340 Sundancer.  There was a water leak in the top of the cabin above the stove, and the previous owner cut the headliner away, but the leak is still there.  I don't want to replace the headliner till I fix the leak.  Any Ideas??
Jowick
Joe
Back to Top Printable version View jowick's Profile Search for other posts by jowick
JADOYLE
Posted: September 17 2006 at 07:31 | IP Logged Quote JADOYLE
MY LAST BOAT IN NEWYORK WAS THE ONE YOU HAVE. I HAD THE SAME LEAK. IF THE HORNS ARE STILL MOUNTED ON THE DECK JUST ABOVE THE STOVE THAT IS ONE OF THE PROBLEMS. THE OTHER IS THE STB SIDE WINDOW MOUNTING SCREWS UNDER THE RUBBER MOULDING IN THE FRONT CORNER.THE DECK IN THAT AREA IS DOUBLE THICKNESS IN THAT AREA AND VERY HARD TO FIND LEAKS. YOU MIGHT ALSO CHECK THE ATTACHMENT POINTS FOR THE HAND RAIL THAT RUNS DOWN THE MIDDLE OF THE FORWARD DECK.
MY BOAT HAD THE HORN AND FRONT WINDOW LEAKS ALONG WITH THE SIDE WINDOW LISTED ABOVE
JAD
Back to Top Printable version View JADOYLE's Profile Search for other posts by JADOYLE
This page was generated in 1.0771 seconds.
