Pro-Line
 BoatUS Boat Groups/Manufacturer Forums>>Pro-Line
Subject Topic: Pro Line 32 Express problems Post ReplyPost New Topic
Pinesmarco
Posted: August 17 2006 at 18:27 | IP Logged Quote Pinesmarco
 I own a 2005 ProLine Express with a pair of Verado 250 HP engines. From the beginning the aluminum engine bracket moved when the boat accelerated/decelerated creating a "snapping" noise. I had concernes about the stresses cracking the bracket. It has taken one year for ProLine to provide a new aluminum bracket on the stern which the dealer installed and now seems OK. I have also had terrible problems with the windshields leaking huge quanities of water into the boat through (under?) the seals on a choppy day. I am still working to get these problems fixed, I guess I'll have to fix it myself. Has anyone else had these problems?
Snowbird Boater from Long Island and Marco Island
Back to Top Printable version View Pinesmarco's Profile Search for other posts by Pinesmarco
Steven Alan Fry
Posted: April 06 2007 at 22:53 | IP Logged Quote Steven Alan Fry
I own a 2003 33 Walk, and have window problems also. Mine is corroding at the intersections of the frame as there is a dissimilar metal used for fasteners (likely stainless) that sets off galvanics with the salt water. It is corroding internally, lifting the painted finish off from inside. It looks terrible, and is structurally melting the frame. Pro-Line replaced it once, and it is back worse than before. Now they are refusing to get the supplier involved because they fear I will sue the supplier?! Blame the customer!
Owner 2003 Pro-Line 33 Walk
Back to Top Printable version View Steven Alan Fry's Profile Search for other posts by Steven Alan Fry
This page was generated in 1.8281 seconds.
