Four Winns
 BoatUS Boat Groups/Manufacturer Forums>>Four Winns
Subject Topic: Throttle Cables Post ReplyPost New Topic
Bake
Posted: July 22 2006 at 13:26 | IP Logged Quote Bake
I have a 2004 Fours Winns 288 Vista Cruiser.  I have replaced the throttle cables once.  The second set works better but still has "stiff" spots in moving the throttles to or from full throttle.  This is especially aggravating when one is docking in a new environ.
Anyone have or had similar problems?
Bake
Back to Top Printable version View Bake's Profile Search for other posts by Bake
jvalich
Posted: July 28 2006 at 09:49 | IP Logged Quote jvalich
Yes, have your dealer call Volvo tech and ask about shimming the cable attachemnt lever on the outdrive.  My dealer did that per Volvo's recommendation and it helped.
Jvalich
2004 Four Winns 288 Vista "Mental Floss"
2004 Ford F-250 SD Crew 4x4 Powerstroke 6.0
Lakeland, FL
Back to Top Printable version View jvalich's Profile Search for other posts by jvalich Visit jvalich's Homepage
Bake
Posted: July 29 2006 at 19:24 | IP Logged Quote Bake
  Jvalich,
Thanks for your response!  My dealer has been very nice.  I will show him your response.  Thanks again.
Bake
tradeup
Posted: August 24 2007 at 16:35 | IP Logged Quote tradeup
I have a 268 FW cruiser also -- The throttle cable is not really the problem -- The transmission OD cable is really the culpert -- I just had mine replaced and shifting and throttle is once again finget tips -- Good luck --
Tradeup - Sarasota, FL
Back to Top Printable version View tradeup's Profile Search for other posts by tradeup
Certified
Posted: January 12 2008 at 11:10 | IP Logged Quote Certified
When replacing cables on your volvo products do your self a favor and get the volvo exact cable thery are night and day compared to the teleflex cable use by four winns. You'll be so happy you did
Back to Top Printable version View Certified's Profile Search for other posts by Certified
tradeup
Posted: January 12 2008 at 13:24 | IP Logged Quote tradeup
I have the same FourWinns and just had the shift cable replaced because it took brute force to shift -- My mechanic used the factory parts and it is now finger tip once again -- He says the corrosion just gets to it, so you can get used to about three years of use until next time -- Happy boating --
Certified
Posted: January 12 2008 at 13:49 | IP Logged Quote Certified
The volvo exact cables will last much longer than the factory supplied teleflex cables. The cable itself "inside the jacket " on a teleflex is a s.s. core where a exact cable is a cable type core with a coating for imporoved throttle and shift feel and also provides longer cable life
This page was generated in 1.0938 seconds.
