O'Day
 BoatUS Boat Groups/Manufacturer Forums>>O'Day
Subject Topic: O’Day 28 Bilge Drainage Post ReplyPost New Topic
shrkbait
Posted: July 11 2006 at 23:42 | IP Logged Quote shrkbait
I own an '86 Oday 28.  The stuffing box is leaking a little, but that's not my issue.  The water has nowhere to go, the bilges under the engine drain pan don't seem to drain down to the main bilge where the bilge pump is located.  Any '86 owners know what the deal is?  Maybe there is a small drain that is clogged that I have not located?  Thanks.
Back to Top Printable version View shrkbait's Profile Search for other posts by shrkbait
soliloquy
Posted: September 14 2006 at 15:03 | IP Logged Quote soliloquy
An Oday 28 owner in an other forum explained that the grounding wire that runs throughout the boat runs between the engine drain pan and the main bilge in a very small hold which gets plugged up easily.  I haven't been able to find this hole myself, however, I'm going to be removing the engine in a few weeks to work on it so will have more access to that area.
Back to Top Printable version View soliloquy's Profile Search for other posts by soliloquy
This page was generated in 3.1719 seconds.
