| Posted: July 12 2006 at 12:00 | IP Logged
Quote: proveick ......... There is hardly any room to access the unit.
Well, that's par for the course for about anything on any boat. You may have to remove something to get to it. Also, lights and mirrors might help you see the area.
Just keep tracing. Unless it's shooting out of something under pressure, whatever is leaking is above or level with where you see the leak.
Quote: I'm wondering if the a/c drain line drains into the sump under the step and is leaking.
If it does, you should be able to tell by looking at the connections to the sump. On mine, there's one from the head compartment comming in and one to the thru-hull going out. There are a couple more inlets that are plugged.
Edited by rwidman on July 12 2006 at 12:05
__________________ Ron
soon to be Camano Troll
Glastron GS249
North Charleston, SC
