Sabre
 BoatUS Boat Groups/Manufacturer Forums>>Sabre
Subject Topic: Sabres Post ReplyPost New Topic
Bob Adriance
Posted: July 06 2006 at 16:46 | IP Logged Quote Bob Adriance
Let's try a question. I need to replace the mast boot on my 362.
Does anybody have any suggestions on which boot works best? I got
one at West Marine (not installed yet) made by Sailing Specialties
that lis designed to be adapted to any mast. Will that do the job? I'm
always skeptical of the one-size-fits-all approach.
Bob Adriance
Edited by Terri Parrow on July 20 2006 at 16:04
Bob Adriance Editor, Seaworthy
Back to Top Printable version View Bob Adriance's Profile Search for other posts by Bob Adriance Visit Bob Adriance's Homepage
Jim Schofield
Posted: July 06 2006 at 17:00 | IP Logged Quote Jim Schofield
Hi Bob,
Just got logged on.  If you posted a picture, I can't open it.
Back to Top Printable version View Jim Schofield's Profile Search for other posts by Jim Schofield Visit Jim Schofield's Homepage
Terri Parrow
Admin
Admin
Posted: July 06 2006 at 17:03 | IP Logged Quote Terri Parrow
You should be able to see it now.
Terri Parrow
Vice President
BoatUS Internet Operations
Back to Top Printable version View Terri Parrow's Profile Search for other posts by Terri Parrow Visit Terri Parrow's Homepage
Passion
Posted: August 30 2006 at 15:22 | IP Logged Quote Passion
Best mast boot I have used is Spartight! Ive used it on a Sabre 38 and a J44.
Works great!
Back to Top Printable version View Passion's Profile Search for other posts by Passion
sailjt
Posted: August 30 2006 at 19:18 | IP Logged Quote sailjt
Bob,
I just moved my 362 from Florida to Georgia.  The spartite came out with a little coaxing but went right back in with some vaseline.  I did buy the new boot from West Marine and used it uncut during shipping to close off the collar from rain.  Just before I stepped the mast, I cut the boot at the top to a bit smaller than 19".  It slid onto the bottom of the mast and up over the spartite.  After the mast was stepped, it clamped it to the mast and to the deck collar and it is working great!
Jim
Edited by sailjt on August 30 2006 at 19:22
Jim
sailjt@aol.com
Back to Top Printable version View sailjt's Profile Search for other posts by sailjt
Bob Adriance
Posted: August 31 2006 at 08:47 | IP Logged Quote Bob Adriance
Thank you both. I looked in the West Marine catalog and didn't see
Spartite, only a Sailing Specialties Universal Mast Boot. Is that the
same thing?
Bob
Maybe it's because I've always owned older boats, but I'm really
enjoying the way the 362 sails. It moves nicely, even in a slight
breeze.
sailjt
Posted: August 31 2006 at 10:57 | IP Logged Quote sailjt
Bob,
Spartite is an epoxy that when mixed is liquid.  Once the mast is stepped, you form a "dam" with some materials in the spartite kit, and then pour in this liquid between the mast and the deck collar.  If you don't use spartite, then you must put in wooden blocks or rope between the collar and the mast.  Once this is done, which is usually not water tigtht unless you use spartite, you must then put a vinyl or rubber "boot".  This boot is tight around the mast about 8" above the deck and then it is tight around the collar just above the deck and sheave collar.  This is to keep the rain out.  Mine is also hose clamped top (at the mast) and bottom (at the collar).  If you use spartite, it becomes a permanant part of the mast and comes out with each mast pull and back in when it is stepped.  Be sure to follow the spartite directions so it will come out easily when the mast is pulled.
Nan, at Hall Spars, recommends the use of spartite and has also been a great source of info when I was stepping the mast.  nan@hallspars.com
Good luck, Jim
Jim
sailjt@aol.com
sailjt
Posted: August 31 2006 at 10:59 | IP Logged Quote sailjt
Bob,
One more thing.  If your mast is not out, the boot you bought can be cut so it can be put around the mast.  Inside their box, you will find some glue to seal it back up at the point you cut it.
Jim
Jim
sailjt@aol.com
Bob Adriance
Posted: August 31 2006 at 11:09 | IP Logged Quote Bob Adriance
I'll be darned; I never knew such a thing existed. Thanks!
