| Author |
lbi4fun "Seaman Recruit"
| Posted: October 04 2005 at 00:00 | IP Logged
I have been using my new 31PC for the pas couple of weeks. It has a twin 6.2MX 320HP with Bravo III, I am able to cruise at 3800RPM with 31MPH and burning 29GPH or .9GPM, is that about right? I was reading the review on boattest.com and they have it burning 18.6GPH at 3500RPM with 31MPH, granted I might have more of a load than the test boat was.
What are you getting GPH or GPM on a similar size boat?
LBI4fun, 2005 Formula 31PC T-Merc 6.2MX 320HP
Back to Top  |
MarkT "Seaman Recruit"
| Posted: October 05 2005 at 00:00 | IP Logged
That sounds about right.
At 1GPNM we can typically do about 32knots or 37mph at 4000RPM if its trimmed just right. The way the boat is trimmed makes a difference. I try to keep the I/O's trimmed up as high as possible with as little tabs as possible. We have the same engines as you do but your boat's about 2000lbs heavier than ours so 1.06mpg at 3800RPM is right in line.
Is your bottom painted? I found that after we had our bottom painted we lost about 2knots at WOT. Test boats typically don't have their bottom's painted and they're not loaded with food, drinks, cloths, extra anchor, dinghy, dinghy motor, etc. Perhaps once your engines are completely broken in they may get slightly better MPG, but I wouldn't expect much better.
Do you have a GPS? GPS's are much more accurate than the Speedo that comes on the boat.
Edited by MarkT on 05 October 2005 at 1:03am
The SALLY P. a 2002 Formula 31PC MarkT
Back to Top  |
Thanks MarkT, the bottom is not painted yet. I do have a GPS as well and will compare it to the Smartcraft to verify the numbers. I was just surprised by the huge difference to the test results on boattest.com.
Back to Top  |
DavidK "Seaman Recruit"
First compare apples to apples. Run your cruise at the same rpm as they did, then see what your fuel burn and speed is. I wouldn't expect it to be better, but your info will be more accurate.
I have a 29PC w/twin 454 carbed. I run a cruise at 3200 RPM at 32MPH and burn 17-18GPH total. I have bottom paint, but slightly different boat.
Back to Top  |
DavidK, I have tried that but was not able to come to the test boat numbers. Actually what you have for numbers is what I expected, I guess I will have to play with it for a while to get the best performance. Don't get me wrong, I am more concerned about running it right in the first place and having the best ride performance.
Thanks for all the input.
Back to Top  |
I received this reply from Formula, although the speed they are quoting at 3500RPM is less than what i am getting with a full load but it is close:
Our test results show the 31 PC with 6.2's with the Bravo III's top
speed being 26 MPH, burning 26 GPH at 3500 RPM's, and that is with a
light load (one captain and low fuel). At 4000 RPM's we show 33 MPH,
burning 34 GPH. With this being said I would say you are right where you
need to be.
The performance and range statistics are the result of tests and
projections. However, each boat performs differently based on hull
condition, load weight, altitude, water conditions, driver experience,
and engine tuning.
Formula Boats
Customer Support
Back to Top  |
petes2424 "Seaman Recruit"
| Posted: October 10 2005 at 00:00 | IP Logged
For what it's worth, I'm looking into the PC family and have looked at a 31PC, I was told, you were NOT going to receive the same performance with the 6.2 engines as you have in the past because of the added weight in the 2005 model. I was actually told to upgrade (from a dealer) to the 496 or 8.1 Volvos. He was very adament about it. Something you really never had to do in other year models. So my guess is, you're not the only one with the problem.
Back to Top  |
Don't get me wrong, this is not a problem. The boat actually performs very well with a full load of gas, water, and 8 people. I am very impressed how it is able to plane so easily and stay on plane, I was just trying to make sure I am getting right gas burn rate as I should.
Back to Top  |
always4sale "Seaman Recruit"
| Posted: October 26 2005 at 00:00 | IP Logged
First of all you should not get the 6.2L they are stroked 5.7L and are not good motors either go with the 5.7l 350 Mag or the 496 have seen a ton of problems W/the 6.2L stay away!!!!!!!!!!!!!!!!!!!!!!
Back to Top  |
3 Fog Night "Seaman Recruit"
always4sale wrote:
| First of all you should not get the 6.2L they are stroked 5.7L and are not good motors either go with the 5.7l 350 Mag or the 496 have seen a ton of problems W/the 6.2L stay away!!!!!!!!!!!!!!!!!!!!!! | | |
Bull!, I have not heard nothing that make this engine that bad, just minor everyday items
However, I always feel that more power is better
BTW: I had a 41PC with 450Cummins - Formula makes an incredible boat!
Back to Top  |
I have done a lot of research and have not seen any major problems with this engine out there. I put about 15 hpurs on the boat in about 3 weeks and every thing is top notch on this boat from fit to finish to performance.
always4sale, can you tell what did you base your statement on?
Back to Top  |
| Posted: October 27 2005 at 00:00 | IP Logged
Interesting that always4sale's first post is to blast the 6.2L (377cid) engines. They've been stroking 350's for years, there's alot of hot-rodders running 383's and 408's. Both the 383 and 408 are stroked and milled/bored 350's.
I've got 175 hours on my twin 6.2Ls and besides IACs and impellers have never had a problem.
Just talk to Chevy, the new Corvette Z06 is a 350 bored and stroked to a 427 putting out 505hp. If Chevy believes they can manufacture a small block 427 making 505hp with a warranty, I trust a 377 making 320hp is being a bit on the conservative side.
Edited by MarkT on 27 October 2005 at 1:31am
Back to Top  |
350 bored to 427 ????? I doubt they will last long. The walls must be as thin as paper.
Back to Top  |
| Posted: October 29 2005 at 00:00 | IP Logged
Check it out (the LS7):
http://www.corvettemuseum.com/specs/2006/LS7.shtml
Back to Top  |
Cuda "Seaman Recruit"
I've never heard of any special problems with the 6.2's, and I researched them pretty thouroghly.
Back to Top  |
It is amazing how some people can make statements and vever back them anyway. Talk is cheap, I guess.
Back to Top  |
Talk may be cheap, but Formula's sure ain't.
Back to Top  |
| Posted: October 30 2005 at 00:00 | IP Logged
Cuda, you are right. They are not cheap but I would feel the same regardless of what boat I own. I have done lot of research and demoed many boats and crawled all over them before I chose my boat. Then, you get someone that is a first time and just makes a statement with no backing what so ever, that really erks me. It's like just reading headlines and never finding the real story.
Back to Top  |
