| Posted: May 05 2004 at 00:00 | IP Logged
Greetings Formula Owners and future ones!
Boat US has generously provided us with a proper forum! Their representatives have generously provided us with this forum for evaluation purposes specific to individual manufacturers. Hopefully, it will be as successful as before and allow for individual postings on assorted topics.
I’m keeping (below) the list of “regular” (Formula/Thunderbird) owners who have contributed so you don’t need to re-type your info. If you want, you can just copy/paste into the Family Members thread and update as needed.
This forum will continue to assist you in your search for information about a particular model, provide info and allow you to address the people showing experience on what you’ve got questions/interest about, without having to look through 300 posts to find it.
For those just wandering through these pages, you’ll also get a good grasp on this group by looking through the original 300 or so postings that follow this thread.
I’ve listed the following in (approximate) order of their introduction to this thread.
Oh yeah....I almost forgot... THANKS EVERYONE!!!!!
- 233 Double E
233 Double E - F-233LS Intercepter - (1981). Engine: (Replaced in 2001) Single Chevrolet 350c.i. w/ Holley 650 carb – original Alpha drive
Use: Cruising, skiing tubing & some fishing – Freshwater only
Maintenance done by: Owner
Projects completed: Ladder on swim platform, Refinished swim platform, stereo upgrade from OEM unit, replaced all trailer wheel bearing components, installed skeg guard, installed power inverter, LED conversion on mooring (all around) light
Projects pending: new depth finder, fill in dock bruises, refinish teak bow trim & cuddy doors
Searching for/needs: Fresh Water tank that feeds the Cuddy sink, cheap Lowrance depth finder head unit.
74Formula233 - F-233 (1974). Engine: original Ford 302c.i. & TR drive
Use: Fishing & cruising
Maintenance done by: Owner & Hired Mechanic
Projects completed: Hull paint restored, outdrive stripped & painted, gimball rings, full stand-up hardtop/enclosure, new trailer, trim tabs, engine heads (351W) rebuilt completely
Projects pending: (maybe) re-powering, some misc. interior work, radar
Spongebob - F-20 Sport (1973). Engine: Ford 351c.i. "Cobra Powered"
Use:
Projects completed:
Projects pending:
Doggydoo (Ft. Lauderdale)
#1 F-20ft Sport (1971). Engine: Ford 302c.i. – Original Volvo 250 drive
#2 F-233 (1968). Engine: Chevrolet I6 292c.i.
Use:
Projects completed: rebuilt the 292 motor
Projects pending: rebuilding the B/W Velvet Drive
Searching for/needs: (For the 233) a good camshaft source for the 292. (Clifford performance was too radical).
My3sons – (1969). Engine:
Use: Pleasure/Cruising
Projects completed:
Projects pending:
F233TBRD454 F-233 (1973). Engine:454c.i. – TRS drive
Use: Fishing, diving & going fast
Projects completed: Trim tabs (Lenco), Whipple supercharger, new fuel tank
Projects pending: Trim Tabs, hull paint, new trailer
Monty C – F-233 (1976). Engine:
Use: Currently not being used
Projects completed:
Projects pending: New trailer
Kevin – F-233 (1974). Engine:
Use:
Projects completed:
Projects pending: New motor(s)
Beef - Engine:
Use:
Projects completed:
Projects pending: Complete re-build
Searching for/needs: about everything
Mark T - F-31PC (2002). Engine: (twin) 6.2L – Bravo III Drives
Use:
Projects completed:
Projects pending:
64 Formula - (Mobile, AL)
#1 F-233 (1964) (left-hand drive). Engine: (twin) Volvo Penta 120B
#2 F-233 (1977) Engine: 255 Evinrude VRO (bracket)
Use: Fishing
Maintenance done by: Owner and hired mechanic (not named)
Projects completed: (for the 1964) drive linkage cables
Projects pending:
Searching for/needs: Literature & specifications, determining which one to keep & sell. Stuart can be reached at (251) 753-2045.
Exuma 16 – (1974). Engine: Chevrolet 305c.i.
Use:
Projects completed: re-powering, drive & prop
Projects pending: tuning for right drive/prop combo
Searching for/needs: others with data on cruise speeds, top end speed,fuel consumption, etc.
Cuda
#1 F-20SC (1981). Engine: 355c.i. (Fresh water cooled)
#2 F-302 SR1 (1986). Engine: (twin) 468c.i. , Kaama surface drives
Use: Cruising
Projects completed: Interior, exterior, engine, you name it!
Projects pending: probably everything else
Searching for/needs: #3
mattzeiler - F-302 (1979). Engine: 400hp (twins)
Use:
Projects completed:
Projects pending:
T-jay 233 F-233 ( ). Engine:
Use:
Projects completed:
Projects pending:
Dick_F223 - F-223 (1972). Engine: 5.7L FI Bravo II
Use: Blue Water Fishing
Projects completed: New trailer, replaced engine & outdrive, new fuel tank hoses & fittings, new dash & instruments, new steering, new Morse controls & cables, repl plastic thruhulls with bronze, new half-tower instrument box, rod holders and topriggers, built new port-side seat and tackle locker with fresh water washdown, new helm seat, all new electronics, new nav lights.
Projects pending: Front and Side curtains for the top, Lenco Trim tabs
Searching for/needs: donations to help support Oh Kay J
80FORMULA F20CL - F-20CL (1980) Engine: 470 Mercruiser
Use: Fishing, Cruising, just getting away
Projects completed: Reupolstered Cockpit, New Stereo Sysytem, New Depth Finder, New GPS, Replaced all fuel Lines, Replacing Bad Rear stringer.
Projects pending: Replace horn, Trim Tabs, Top, Overhaull cabin interior, Possible Engine overhaull (in winter), remove bottom paint. Powder coat or paint windshield frame. “Never a problem finding something to do on a 25 year old boat.”
Searching for/needs: Any suggestions for anything above.
Picklefish - F-233 (1967). Engine: TBD, Mercruiser II
Use:
Projects completed:
Projects pending: killswitch lanyard, re-powering
Searching for/needs: Sterndrive compatibility info
Allison Hi-Tech - F-302 ( ). Engines:
Use:
Projects completed:
Projects pending: re-powering with Whipple–charged 502c.i., installing Sportmaster Drives
BryanK - F-34PC (2004). Engine:
Use:
Projects completed:
Projects pending:
BFord1 - F-357 SR1 (1985). Engine:
Use: Cruising
Projects completed:
Projects pending:
Bluesfan550 - F-233 (1968). Engine: 427c.i. w/Bravo III
Use:
Projects completed: Rebuilt trailer, re-upholstering
Projects pending:
bjm0918 - F-233 (1973) Engine:
Use:
Projects completed: gutted interior windshield restored
Searching for/needs: engine size advice
Makksumm - F-233 (1966) Engine: 5.7LD
Projects completed: Stinger re-build
Projects pending: Arch Installation & retractable bimini
F255Vanguard - F-255 Vanguard (1978). Engine: I-4 “470” (twins)
Use:
Projects completed:
Projects pending: complete rebuild
75F233 - F-233 (1975). Engine:
Use: Fishing
Projects completed: Complete restoration and conversion to Center Console with T-top
Projects pending:
Tpenfield - F-242LS ( ). Engine:
Use:
Projects completed:
Projects pending:
Formula Fever (Ft. Meyers FL)
#1 F-20 (1979). Engine: 350c.i. (not running, motor is locked-up), OMC drive
#2 F-233 ( )
Use:
Projects completed:
Projects pending:
Searching for/needs: (For the F-20) This unit is for sale. Hull is in great shape, just needs interior stuff. I have $900.00 invested. Anyone interested call Mark (239) 707-7077.
ahandiman - (Mississippi River – St. Paul, MN)
F-255 Freedom Cruiser (1979) Engine: 260hp Mercruiser
Use: Fishing, cruising, just getting away
Projects completed: Replaced fuel lines and components, replaced ignition components, installed marine band radio and new stereo
Projects pending: Fix tilt, re-upholster, paint entire boat, & more I'm sure I just don't know about yet
