Subject Topic: 50 amp question Post ReplyPost New Topic
courtship
Posted: December 04 2013 at 17:06 | IP Logged Quote courtship
I haven't been on here lately but with winter coming I have some time on my hands. Todays question is about AC power. My 1990 501 has both 50/125 and 50/250 inlets on the Port side and 50/125 and 50/250 cords via the Glendening on the Starboard side. I haven't seen any marinas with 125 in a long time but am wondering if anyone out there has ever tried to use both at the same time. I ask because the house lighting don't need the 250 amp supply (all five air conditioners obviously require it) and if I could run the house on 125 and the air conditioners on 250 it would make power management a breeze.
Does anyone out there have any experience with this issue?
Thanks!
Steve Donock
CourtShip
1990 501 Constellation
Back to Top Printable version View courtship's Profile Search for other posts by courtship
Pats2nd Connie
Posted: December 04 2013 at 19:13 | IP Logged Quote Pats2nd Connie
Unfortunately my main selector switch was broken by my broker during
the "shakedown" cruise he offered to do.   I believe it was welded in
the 1&2 position and when he switched to generator I could never get
it back to 1&2.   Hence I am currently running on only 1cord, I choose
the 250. For now it is not a issue but when I am in Florida for the
summer, I will want the full Monty.
Patrick hoffman
Back to Top Printable version View Pats2nd Connie's Profile Search for other posts by Pats2nd Connie
eshover
Posted: December 04 2013 at 19:40 | IP Logged Quote eshover
Pat - if by "welded" you mean electrically welded due to
shorting circuits. I recommend you open that panel on a
priority basis and examine all electrical connections before
you burn your boat down. I had an issue where I was
docked after a run on the generator and had rolled over to
shore power. I walked up the dock to pay my slip fee and
my wife yelled to me that smoke was filling the lower
salon. I ran back and shut down all electrical sources. I
keep an IR gun on my boat (a necessity in my mind) and
checked the panel and it was hot! I opened the panel and
discovered three loose connections on the the main rotary
switch and one on one of the roll-over switches!! One was
burned so badly that I found some properly sized wire and
replaced it.   Be forewarned!
"Southern Charm"
1986 Connie 500
Back to Top Printable version View eshover's Profile Search for other posts by eshover
Pats2nd Connie
Posted: December 04 2013 at 20:29 | IP Logged Quote Pats2nd Connie
Emory, I have had a couple of electrician look at it. Connection are
fine.   However if I try to go back to 1&2 everything goes dead.   They
say it is the switch. Minimum of 2400 to replace. I have been waiting
for a more experienced guy that could fix the switch or add another
50amp switch to carry the load of a few items. Everything works fine
off of one line until I load it too much and the dock breaker cuts off.
Hence we limit the a/c. Dryer and stove functions.
Patrick hoffman
Grey Goose
Posted: January 10 2014 at 12:20 | IP Logged Quote Grey Goose
Hi Steve
I have a 1987 501 with probably the same power set
up as yours. For some reason the 50/125 blows the
main breaker when I plug it in. But the way it is
supposed to work, when you select all three lines, the
50/250 cord powers the #1 and #2 breaker section.
The 50/125 powers the #3 breaker section. Normally
the 50\250 works powering #1 and #2 & #3 are
combined as the same. Hope that makes sense.
-- Goose --
"Grey Goose"
1987 Chris Craft 501
Back to Top Printable version View Grey Goose's Profile Search for other posts by Grey Goose
courtship
Posted: January 13 2014 at 15:28 | IP Logged Quote courtship
Goose - Thanks! We do have the same set up. What you're describing is what I was hoping. Now to get an extra 50/125 at my slip! It would be nice to say good-bye to power management once in a while.
Steve Donock
CourtShip
Pats2nd Connie
Posted: January 13 2014 at 16:15 | IP Logged Quote Pats2nd Connie
Emory, I'm glad Steve brought this issue up again. It reminds me to
check all thes connections when we return to the boat.
Patrick hoffman
Grey Goose
Posted: January 13 2014 at 16:37 | IP Logged Quote Grey Goose
Steve
The #3 circuit does not draw that much load. If you
have a 30 amp outlet at your slip, why not give it a
try.
Worst thing that could happen is blow the circuit
breaker on the pier. You would have 130 amps
coming in instead of only 100. May just work out for
you.
Edited by Grey Goose on January 13 2014 at 16:38
-- Goose --
"Grey Goose"
Pats2nd Connie
Posted: January 13 2014 at 17:56 | IP Logged Quote Pats2nd Connie
Mine was on one 50 amp and one 30 amp, giving me 80 amps total.
Patrick hoffman
