Subject Topic: Desiel Fuel Manifold Settings Post ReplyPost New Topic
Captcraw
Posted: June 04 2012 at 19:03 | IP Logged Quote Captcraw
Dear Pete37  I met you at Piney Narrows and I would like to communicate with you regarding the Chris Craft 501 Fuel Manifold.  It appears to be 3 Anderson Brass 6 Port Valves.  My boat runs great when the aft valves are what i believe is the off position  and the middle valve crossover is off.  When I would like to switch to the aft tanks do I need to shut off the feed and returns on the engine room tanks ?  It appears to run out of prime when I simply switch the main manifold valves to aft.
Back to Top Printable version View Captcraw's Profile Search for other posts by Captcraw
Pete37
Posted: July 01 2012 at 17:59 | IP Logged Quote Pete37
Hi Captcraw,
I normally only monitor the "Murray Chris Craft Constellation 500" forum.  Pop over to my boat (I'm there a lot of the time) and we can talk about the valves.
Pete37
INTERLUDE
This page was generated in 1.6875 seconds.
