Subject Topic: overheating Post ReplyPost New Topic
Chard
Posted: July 07 2011 at 15:53 | IP Logged Quote Chard
Hello all having overheating issue on my 1978 cc cat 350 chevy single screw.Put new impeller in cleaned heat exchanger,just pulled out to paint bottom,put back in  water.Does fine when running at 2500 rpm when I idle back to dock starts temp to go up any ideas.Also think trans seal is leaking under housing,going to pull out this winter for maint and what not thinking of still using at slow cruise just keep fluid filled love some imput thanks Chard
1978 Catalina 25ft
Back to Top Printable version View Chard's Profile Search for other posts by Chard
Fly Bridge
"Navigator"
Posted: July 07 2011 at 21:36 | IP Logged Quote Fly Bridge
Cap'n  Chard:   2 issues.  1.)  there is a CATALINA FORUM, for Catalina owners.  We would enjoy having you join us there!!  LOT'S of information, and friendly fellows to help solve just about any problem you may have, with your Catalina.
2.) When you idle-down, and temp goes upward, what degrees does your temp gauge display?  If engine water is HOT, check your thermostat, It MIGHT be not fully opening.  How old is your thermostat?  When engine is cold/cool, and you have time, pull thermostat, and place in boiling/warm water.  It should be----- fully open,----- in boiling (212 degrees)  water.
Again, come on over to the Catalina forum!!!!
Regards,  Fly Bridge  (Dan).
1979 Chris Craft,Catalina Sedan FB, 33ft. 2 Helms, 2/5.7. New 2004. Port eng. removed to rebuild. Starboard operating. Presently in "Backyard Dry Dock". Home Port:Holiday,Florida. (danbushey@msn.com)
Back to Top Printable version View Fly Bridge's Profile Search for other posts by Fly Bridge
