Renken
 BoatUS Boat Groups/Manufacturer Forums>>Renken
Subject Topic: shifter Post ReplyPost New Topic
rickyq
Posted: July 04 2011 at 21:17 | IP Logged Quote rickyq
I bought a 95 renken with an inboard motor. runs fine but wont shift from forward to reverse unless tou kill motor first. Is there a safty switch or some thing that can cause this? When out of water & running it will shift
just bought 95 renken 200/w inboard motor. problem is when on ground & running you can shift forward to reverse in water you must kill motor to shift forward to reverse. any ideals?
Back to Top Printable version View rickyq's Profile Search for other posts by rickyq
