Subject Topic: 1990 Chris Craft 372 Catalina Post ReplyPost New Topic
jm14246
Posted: May 23 2011 at 18:30 | IP Logged Quote jm14246
boat has three bilge pumps, in the main engine room, aft cabin and forward cabin.  Are these areas connected in any way so the if the main fails the others would help out for awhile?
Back to Top Printable version View jm14246's Profile Search for other posts by jm14246
boatman66
Posted: May 26 2011 at 08:40 | IP Logged Quote boatman66
JM 14246 YOUR BILGE PUMPS SHOULD ALL BE WIRED SEPERATELY AND HAVE THEIR OWN TRIGGER FOR PUMPING (FLOAT SW)AND THEIR OWN SWITCHES FOR AUTO/MANUAL I HAVE A 294 AND HAVE FOUR PUMPS AND ALL WORK INDEPENDENTLY OF EACH OTHER--IF YOU MEAN FOR THE WATER TO TRAVEL FROM ONE AREA TO THE OTHER YES THERE SHOULD BE AT THE VERY BOTTOM ABOVE THE KEEL INSIDE A WAY FOR THE WATER FROM SAY THE CABIN TO GO TO THE BACK OF THE BOAT HUNT HARD IT SHOULD BE A ONE INCH OR SO HOLE MINE HAS THAT FEATURE-PS FURTHER POSTS SHOULD AND CAN BE MADE ON THE CATALINA LINE SEE IT??THAT IS WHERE WE ALL ARE AND WELCOME ABOARD--FEEL FREE TO POST THERE
1986 294 catalina twin 350's
This page was generated in 0.9043 seconds.
