Subject Topic: Crowne 282 Bow Bilge Pump Post ReplyPost New Topic
BobbyG
Posted: May 16 2011 at 22:16 | IP Logged Quote BobbyG
Hi Guys,
Blowing circuit breaker on front bilge pump on 1994 Chris Craft Crowne 282.  Problem is how to locate and replace.  Traced drain hose outlet under pulpit at bow.  Anchor rope door hatch in cabin shows bilge pump hose going down to bottom with freshwater fill hose line.  Both are secured.  I believe I may be able to remove the front panel holding the anchor hatch door allowing removal of the top ledge plate behind the seats which should expose a tight view of the water tank and hopefully front bilge pump.
Has anybody been there before.  Am I on the right track?
Also,  anybody have manuals on this model boat?
TY in advance....
Edited by BobbyG on May 16 2011 at 22:20
1994 Chris Craft
Crowne 282
CANADA
Back to Top Printable version View BobbyG's Profile Search for other posts by BobbyG
BobbyG
Posted: May 26 2011 at 22:47 | IP Logged Quote BobbyG
Hi Guys,
Found the cabin bilge pump location.  It is below the bottom stair going into the cabin. Access is buy pulling vertical riser below bottom stair.  There is a small notch cut out on top left corner so you can get your hand in.  Also shower sump access is available here.
1994 Chris Craft
Crowne 282
CANADA
