Carver
Subject Topic: Starting circuit. Post ReplyPost New Topic
DAVECAD2.0
Posted: May 09 2011 at 14:07 | IP Logged Quote DAVECAD2.0
1980 Santa Cruz 26"
Repowered from a single right hand inboard 351W to a single left hand 351W.
Did all the standard swaps: Indexed the Velvet drive, changed starter, changed the distributor gear.
I have this qurky porblem. When I try to start the engine it cranks for say thirty seconds and when I let off the key it fires right up. Runs smooth.
Did I miss something in the wiring, or does the module in the Prestolite distributor need to be changed? This is truly weird.
Thanks for any help.
Ignorance is an educational deficiency. Stupidity is self taught.
Back to Top Printable version View DAVECAD2.0's Profile Search for other posts by DAVECAD2.0
