Subject Topic: Engine hour meters Post ReplyPost New Topic
tomconfusion
Posted: November 20 2010 at 11:55 | IP Logged Quote tomconfusion
I guess this is a really dumb question, but can anyone tell me what the pictured engine hour meters are reading? I am guessing the port meter is reading approximately 315 hours, 35 minutes, and the stbd meter approximately 349 hours, 45 minutes. If this is incorrect, please enlighten me as to what the correct readings would be and if possible some instruction on how to read them. I like to log in the engine hour readings whenever we run them or perform any work on them, but a review of my log shows I am recording lower hours in some of the more recent entries so I have misread the meters at one or more times. Since I purchased this boat second hand, I also wonder how one can get approximately 35 hours differance in the run time on two engines in the same boat??
Any assistance or advice gratefully received.
???tom
Maintenance Officer
1984 381 Catalina
Back to Top Printable version View tomconfusion's Profile Search for other posts by tomconfusion
boatman66
Posted: November 21 2010 at 09:07 | IP Logged Quote boatman66
TOM RUN THEM AND WATCH THEM RUNNING --I BELIEVE THE SMALL WHITE HAND INDICATES SECONDS OR THE FACT THEY ARE RUNNING-THE LARGER HAND INDICATES MINUTES AND THE SMALL DARK HAND IS HOURS-- WATCHING THEM RUN FOR SAY 15 MINUTES WILL TELL--SO IF THE SMALL DARK HAND IS HOURS THEY APPEAR TO BE PRETTY CLOSELY MATCHED--PORT 33HRS STBD 35HRS MEANING EITHER A STOPPAGE OF SOME KIND ON THE PORT ENG AND THE STBD ENG RUNNING LONGER--MAYBE LIMPING BACK TO PORT ON ONE ENG??ETC.--WHICH IS NOT UNCOMMON ON OUR BOATS MINE INCLUDED--HPOE THIS CLEARS THIS UP FOR YOU--BOATMAN 66
1986 294 catalina twin 350's
boatman66
Posted: November 21 2010 at 09:14 | IP Logged Quote boatman66
PS A WAY TO BRING THEM INTO BOTH READING THE SAME IS TO ENERGIZE THE LOWER READING ONE AND LET IT RUN UNTIL THEY BOTH MATCH--JUST TURNING ON THE KEY AND NOT FIRING THE ENG. SHOULD DO THE TRICK-- EVERY TIME YOU ENERGIZE THEM (ELECT) THEY RUN-- ANOTHER WAY IS TO REPLACE THEM WITH NEW DIGTAL ONES WHICH IS WHAT I DID--SOME OF THE DIGITALS EVEN HAVE RESET BUTTONS--REMEMBER THEY ARE A REFERENCE INDICATOR FOR GENERAL PURPOSES AND NOT ENTIRELY RELIABLE AS TO ACTUAL HOURS ON YOUR ENGINES
boatman66
Posted: November 21 2010 at 09:18 | IP Logged Quote boatman66
AGAIN 320 PORT 340 STBD NOT TOO FAR OFF
tomconfusion
Posted: November 21 2010 at 12:20 | IP Logged Quote tomconfusion
Hello Boatman66
Thanks for your assistance. Just for the record, I also have returned to port on only one engine several times, but not yet with this boat (knock,knock!). I did have an engine in this boat die on me in a lock which is more than a little exciting. You don't have enough room in a lock to get enough speed to let the rudders overcome the turning thrust from the running engine so the boat just turns in a circle. We finally got the engine running and I backed out of the lock.
Referring to the pictures, I have watched the meters run with the engines on and I can determine that the longest hand which happens to be blue moves the fastest of the three. The middle sized white hand moves slower, and the little green hand is the slowest of all. The innermost circle of numbers are green so I had assumed the little green hand should be reading them. That would make the port meter reading a little more than 300 somethings (minutes, hours,?) and the stbd meter reading a little less than 360 somethings. I guessed the middle sized white hand was indicating where in the 60 somethings spaces the green hand actually was. If this is the case and we assume the little green hand is reading hours, then I can assume that one or more of my previous readings were in error. I don't feel too bad about this as the sales organization that sold me the boat advertised the engine hours at around 675. I could not tell you how they arrived at that number, but one would think they would know what they were doing. I think I will try your suggestion and run the engine for 5 or 10 minutes; I should be able to tell if the biggest hand is reading minutes and that would give me a handle on what the other hands are trying to tell me. Do I pass, Teach??
Even if I don't (pass that is), Thanks.
1984 381 Catalina, twin 454's
???tom
Maintenance Officer
1984 381 Catalina
boatman66
Posted: November 22 2010 at 15:44 | IP Logged Quote boatman66
YEH SORTATHE WHITE HAND IS ON TOP-SECONDS-ALSO IS AN INDICATOR THE THING IS WORKING- THE LONG HAND IS SECOND IN THE STACK-MINUTES AND THE BOTTOM HAND IS HOURS--ALSO LOOK THE THINGS UP ON THE NET-THIS PLACE IS SO FULL ON INFO--NOW YOU ARE GOING TO HAVE TO CHANGE YOUR NAME TO TOMKNOWSALSO JUMP TO THE CATALINA LINE ON THE SAME PAGE --SHOULD BE RIGHT ABOVE OR BELOW THIS POST LINE --THAT IS WHERE WE ALL ARE-CATALINAS-AND POSE THE QUESTION AGAIN AND LETS SEE IF THERE IS ANY MORE INFO ON YOUR TIMERS--SEE YA THERE 66
boatman66
Posted: November 22 2010 at 15:47 | IP Logged Quote boatman66
GOTTA CONFESS THE WHITE HAND STATEMENT YOU MADE AS MOVING REAL SLOW IS THROWING ME OFF-YOU SAID IT RUN THEM AND TIME THEM--------- YOU PASS
boatman66
Posted: November 22 2010 at 15:48 | IP Logged Quote boatman66
SEE THE BOAT AT THE TOP OF THE PAGE?THAT IS NAUTI-CAT"S BOAT
Nauti Cat
Posted: November 22 2010 at 17:58 | IP Logged Quote Nauti Cat
Hi Boatman...mine is in the mix of boats Brian collected, it changes each time the page is refreshed.  I wonder if he is taking more...you sent me a good one of yours...
Nauti Cat in NY
Formally owned by a
1985 Catalina 280
"MY WAY"
BrianAzar
Admin
Admin
Posted: November 22 2010 at 18:39 | IP Logged Quote BrianAzar
Hi Nauti, boatman and tom,
I just wanted to pop in and let you know that yes I am still taking pictures. I will be adding more pictures to the rotation as I get more. I don't want to do just one at a time, and have already had a few more submissions since the launch of the new skin. If you'd like to submit more pictures, please post them in the Pictures? thread, so I can keep an order of all pictures that have been submitted and by who. Thanks!
BoatUS Web Developer
Back to Top Printable version View BrianAzar's Profile Search for other posts by BrianAzar
tomconfusion
Posted: November 23 2010 at 01:48 | IP Logged Quote tomconfusion
Hello Boatman, Nauti, & Brian
Boatman - Have not been back to boat yet to run hour meter test. Probably get back the week after Thanksgiving. I am going to have to start winterizing the thing pretty darn soon or I may get to play the repower game (many $$$). Will let you know results then.
Nauti Cat - neat boat! That picture does not look like NY though.
Brian - Sure wish I had a picture of my boat to send you. I have pictures of all my buds' boats and towboats and excursion boats, but none of my boat (actually wife's boat, I just have the maintenance contract). It is just kind of a mundane boat so it is probably just as well I don't. Anybody know where there is a mirror cliff that is accessable by water??
???tom
Maintenance Officer
1984 381 Catalina
Nauti Cat
Posted: November 23 2010 at 08:29 | IP Logged Quote Nauti Cat
hahahaha TomC...that is actually a photo of Boatman's baby down in FL!  Mine hibernates on the hard for a few months every year...
Nauti Cat in NY
Formally owned by a
1985 Catalina 280
"MY WAY"
tomconfusion
Posted: April 30 2011 at 06:19 | IP Logged Quote tomconfusion
Wanted to post my conclusions on this subject in case anyone else was interested in reading their engine hour meters; CC made a bunch of boats so I would guess there are more than just 2 of these meters out there. Anyway, finally got a chance to run engines for an hour and check meter function. This is how these particular meters actually read:
The white hand evidently moves to indicate the meter is working. If it is showing anything else, it is in less than 1 hour increments and of no value to me from a maintenance standpoint (maybe someone else would be interested in engine minutes or seconds, I don't know).
The longest blue hand is hours and reads directly off the outermost scale, ie. port meter is showing 36 hours.
The shortest green hand is counting in the blue hand revolutions in 60 hour increments and reads off the innermost scale, ie. the port meter is showing 300 plus hours, in this case 336 hours.
Since we believe the meters are in their 2nd 600 hour cycle (I hope they are not in their 3rd cycle), I need to add 600 hours for the first cycle so the actual engine hours on the port engine seem to be 936 hours.
I wonder if I can go back now and sue the previous owner and sales agent for advertising the engine hours as 675;alas, probably not; craveat emptor and all that stuff.
Thank you all for your assistance; hope everyone had a good winter.
???tom
Maintenance Officer
1984 381 Catalina
This page was generated in 0.9380 seconds.
