Uniflite
Subject Topic: changing/removing fuel tanks Post ReplyPost New Topic
Gran Matthew
Posted: November 13 2010 at 11:21 | IP Logged Quote Gran Matthew
I have just purchased a 1973 34' Uniflite sport fisherman with 100 gal. fuel tanks. Has anyone "easily" removed these long tanks? I am thinking I will have to cut the cockpit floor to pull them through and then re-fiberglass?
 Any suggestions will be greatly appreciated.
Thanks,
Rod
Back to Top Printable version View Gran Matthew's Profile Search for other posts by Gran Matthew
Aerotow1
Posted: November 13 2010 at 14:55 | IP Logged Quote Aerotow1
Rod,
I am looking forward to following this thread.  I am currently looking at that very same model and was curious about how to do that very same thing.
Where are you located, I am curious if you purchased your new boat in the Seattle area...I looked at one near Seattle and it looked as though the tanks would need to be replaced.
Thanks,
Dan
1972 Salty Pup "Frisson" (Means intense moments of excitement a shudder or a thrill)
Back to Top Printable version View Aerotow1's Profile Search for other posts by Aerotow1
Gran Matthew
Posted: November 14 2010 at 06:58 | IP Logged Quote Gran Matthew
Dan,
We are in the Fraser Valley, B.C. and bought our Uniflite in Renton...yes, the Seattle area. I will replace the tanks since they are the original, and some rust is present. I am going to try POR 15 for the time being...a rust neutralizer. Supposed to stop the rust and prevent it from returning. I have not read any reviews from users.
Rod
Comogene
Posted: December 26 2010 at 22:21 | IP Logged Quote Comogene
Rod:
Can't help you on the fuel tanks as mine were inside and under the salon.  No fiberglass to cut, just wood.
As to the POR 15, mechanic used it to coat the oil pans and swears by it.  I just coated my outboard tank as salt water had gotten to the crimped edge where the sides meet the bottom.
You might try sanding any area of the tank that looks bad, apply Marine-Tex and after sanding to smooth, apply POR-15.
Gene
Back to Top Printable version View Comogene's Profile Search for other posts by Comogene
Gran Matthew
Posted: December 26 2010 at 23:40 | IP Logged Quote Gran Matthew
Thanks for the reply, Gene. My tanks are also under the salon, and the floor is fiberglass. My best bet will be to cut the cockpit floor and remove each tank. Once each tank is out, I will check the rust condition and either POR 15 or replace.
I have a window problem as well, but I'd better go start a new thread for that one.
Rod
This page was generated in 6.2031 seconds.
