Subject Topic: 1990 427 Catalina Electrical Problems Post ReplyPost New Topic
OSCAR
Posted: October 05 2010 at 13:18 | IP Logged Quote OSCAR
I have a 42 ft. 1990 Catalina with gas engines. My 12 volt power has gone dead. The batteries are good and show full voltage I have power in my DC breaker panel, The batterie switches are clean. The grounds all seem tight. but nothing 12 volt works. Any Ideas Thanks
1990 42 ft. Catalina
Back to Top Printable version View OSCAR's Profile Search for other posts by OSCAR
Capt. Heavy
"First Mate"
Posted: October 06 2010 at 23:28 | IP Logged Quote Capt. Heavy
Hey, Oscar, try logging on to the CC Catalina site and post your question there. A lot of good guys who are eager to help. See you there, Capt. H.
Capt. Steve, Stuart Fl. Chris Craft Owner- 25 catalina, 331 corinthian. Licensed Capt. 20 Years, Certified diver for 30 years. Avid fisherman.
Back to Top Printable version View Capt. Heavy's Profile Search for other posts by Capt. Heavy
Posted: October 22 2010 at 11:17 | IP Logged Quote diveryates
Oscar,
No 12VDC on a boat should be fairly straight forward to troubleshoot. Start at the battery and trace the wires/cabling. Odvously, there's something disconnected or loose somewhere. Dissconnect shore power 1st to avoid confusion. Check your grounding cables again. These cables run from the ground post on the batteries to the engine blocks. Be sure you know how to use a volt/ ohm meter and the theory of disconnecting curcuits to read contuinuity and to test for the presence of voltage. You'll find it. Take you time, think it thru 1st before raising a screwdriver. Using a digital camera as a tool for visual inspection. It's handy where one can upload the images to a computer for putting the images in order and zooming-tis helps in a visual inspection too- lottsa pictures can clarify things and you can post them to the forum for further consultation.
best, Diver
This page was generated in 3.2813 seconds.
