Subject Topic: Outdrive Trailer Switch Post ReplyPost New Topic
vinandrea
Posted: September 12 2010 at 09:13 | IP Logged Quote vinandrea
Hello,
I am a relative newbee to boating.  I have a 2003 Sea Ray Sundeck with a Mercruiser 5.0 MPI engine.  I can activate the trim switch on the throttle lever to lift the outdrive, however, how do I lift the outdrive further into the trailering position?  I have tried to continue to push the trim switch on the throttle lever without any luck.  Thanks.
Vince
Back to Top Printable version View vinandrea's Profile Search for other posts by vinandrea
Secondbesttoy
Posted: September 13 2010 at 10:40 | IP Logged Quote Secondbesttoy
There should be a "Rocker Type" button at the top of the Throttle/Shift Lever, that is for the tilt and trim.  About half want down the handle should be a larger square button.  Hold that in and the outdrive should raise to the Trailer Position.  You can hear the motor change sounds when it is at the top.
Back to Top Printable version View Secondbesttoy's Profile Search for other posts by Secondbesttoy
vinandrea
Posted: September 14 2010 at 07:25 | IP Logged Quote vinandrea
Thanks for your answer.  I do not see a larger square button on the throttle handle.  I have the rocker switch on the top of the throttle lever and I can get the outdrive to tilt and trim when I move this switch.  The only other button is a large round button at the pivot point of the throttle lever.  However, I believe this is for disengaging the transmission so that I can rev the engine without the prop turning.
Any other thoughts?
Vince
chuck1
Posted: September 14 2010 at 10:22 | IP Logged Quote chuck1
If you only have the rocker switch then all you have to do is lightly press the rocker switch down until it stops. Now lightly press it up, when the drive stops the 1st time that is the top of the running position. Now press it again harder when it stops the second time that is the top of the trailer position.
2006 240 SunDeck MS Judy
350 MAG MPI BR3
North GA Mountains
Back to Top Printable version View chuck1's Profile Search for other posts by chuck1
midway
Posted: September 14 2010 at 12:20 | IP Logged Quote midway
What Chuck1 said is correct.
1994 GMC K1500 2004 Sea Ray 185 Sport 4.3L Alpha I
Back to Top Printable version View midway's Profile Search for other posts by midway
Secondbesttoy
Posted: September 14 2010 at 12:36 | IP Logged Quote Secondbesttoy
Sorry my ansawer was out dated...guess they have changed since I bought mine.
midway
Posted: September 14 2010 at 12:53 | IP Logged Quote midway
My 87 had the 2 button setup, they have changed to the one button system now, I do not know when the change started.
vinandrea
Posted: September 14 2010 at 16:24 | IP Logged Quote vinandrea
Thanks everyone for your answers.  I will give it a try.
Vince
vinandrea
Posted: September 29 2010 at 19:54 | IP Logged Quote vinandrea
Thanks again Chuck1.  I tried the pressing the rocker twice and this worked.  Thanks again for the advise.
Vince
chuck1
Posted: September 30 2010 at 11:41 | IP Logged Quote chuck1
You are welcome, glad we could help.
350 MAG MPI BR3
North GA Mountains
