Subject Topic: What transmission fluid to use: 1985 Comm Post ReplyPost New Topic
PanchoCC
Posted: August 22 2010 at 14:26 | IP Logged Quote PanchoCC
What transmission fluid to use: 1985 Commander 337, 7.4L In-line in-board drive
The manual states the following:
“Use only automatic transmission fluid (ATF).  All automatic transmissions fluids currently used in passenger cars are suitable for use in transmission.“
So, what fluids were they using in 1985 ?
One guy on K dock told me use type A.
The marina sold me Dexron III (3).
1985 Commander 337; 7.4L; In-line in-board drive
Chriscraft 337 Commander (1985), twin 454 Mercs w/quadrajets, IB drives, Onan 6.5 Genset.
Back to Top Printable version View PanchoCC's Profile Search for other posts by PanchoCC
Posted: August 23 2010 at 17:48 | IP Logged Quote diveryates
Pancho CC,
Generally speaking, Dextron III is the one to use. Borg Warner and Paragon Gear specify it.
You can also confirm this at:
http://www.marineengine.com/
best, Diver
....P
Posted: April 05 2011 at 13:26 | IP Logged Quote ....P
Hi Pancho,
diveryates speaks the truth.  On many of the older models there was a spec for a fluid that is no longer available, but the Dex III is backwards compatible with most (or all) of these.
regards,
P
1973 23' Lancer Inboard, 427 power
1966 38 Commander Express, 427 power
1966 20' fiberglass Sea Skiff
1956 17' CC Sportsman
http://www.chriscraftcommander.com
Back to Top Printable version View ....P's Profile Search for other posts by ....P
This page was generated in 1.6719 seconds.
