Subject Topic: 501 Generator room blower Post ReplyPost New Topic
scottflys2
Posted: August 09 2010 at 22:41 | IP Logged Quote scottflys2
Can't seem to find the blower in the generator room there is a switch on the ac panel but don't hear anything running when switched on. Is it outboard of the genset? thanks
Gemba
Back to Top Printable version View scottflys2's Profile Search for other posts by scottflys2
Banjoman
"First Mate"
Posted: August 10 2010 at 07:20 | IP Logged Quote Banjoman
Gemba - if you have the typical galley down 501, it has virtually the same galley as the 500. The blower is located next to the refrigerator.  You have to pull the frige to get to it.  It is easily replaceable and can be purchased from McMaster-Carr or similar vendor.  Usually, these brackets rust away and the motor becomes fouled and/or corroded and simply quits.  I find it odd that you can turn on the breaker and it doesn't trip. But the only way to fully determine the condition is on of two ways; if you have room, crawl over the pumps and junk on the starboard side of the generator room and shine a flashlight up in the blower opening to see how badly the mounting brackets are rusted.  If you are lean and mean you can reach up in there and give it a "shake" and maybe see if the motor turns. The other way is to simply replace. I would imagine at this age of your boat it is ready for replacment.  I replaced mine in an afternoon.  Good luck!
Emory
Capt. G. Emory Shover
m/v "SOUTHERN CHARM"
Eastern Marine Services, LLC
www.easternmarineservices.com
scottflys2
Posted: August 10 2010 at 09:35 | IP Logged Quote scottflys2
Banjoman Hi
Gemba has galley up, gen is under floor in passageway across from office.  What size is the blower on your boat?   Thanks for help
Gemba
Banjoman
"First Mate"
Posted: August 11 2010 at 17:39 | IP Logged Quote Banjoman
Gemba - I replaced mine several years ago and couldn't begin to tell you what size it is.  You should post this request on the Constellation forum, you may get some more information.
Emory
scottflys2
Posted: August 11 2010 at 19:40 | IP Logged Quote scottflys2
Thanks Banjoman
Hope to be back on board Gemba next week and will take another look for blower it must be outboard of genset on port side.  scott
Gemba
