Subject Topic: chris craft windshield R&R Post ReplyPost New Topic
scubapop
Posted: July 13 2010 at 12:59 | IP Logged Quote scubapop
Anyone have know how to remove the windshield from a 1974/75 chris craft 25 express day cruiser
Back to Top Printable version View scubapop's Profile Search for other posts by scubapop
Berg
Posted: July 13 2010 at 14:42 | IP Logged Quote Berg
scubapop- I haven't removed them on earlier models but on my 83 it is just held in with screws around the perimeter that go from the aluminum and anchor into the fiberglass superstructure. They are hidden on the later models by a plastic strip that locks into a channel in the aluminum. If you are careful with a flat blade screwdriver you can pop out the lock strips. The older ones may not have the lock strips. I think there are also 2 large screws on the back of the wing windows
1983 Chris Craft Catalina 251
Marine Power 305K GM
Venture 6000lb Trailer
Eastern Suffolk County
Long Island, NY
Back to Top Printable version View Berg's Profile Search for other posts by Berg
scubapop
Posted: July 13 2010 at 16:49 | IP Logged Quote scubapop
Berg---Thanks for the input---as soon as the rain stops I'll check.  I know there is a plastic strip runnig along the lower portion of the frame for the two front panes perhaps the screws you reference are under it.    Thanks again for your help
Posted: July 13 2010 at 19:42 | IP Logged Quote diveryates
Scuba Pop,
I think I have the original installation instructions from 'Water Bonnet'. They are part of Taylor Made these days http://www.waterbonnet.com/.
I will EMail you the sheet if you like: diveryates@yahoo.co.
Best, Roy
scubapop
Posted: July 13 2010 at 21:06 | IP Logged Quote scubapop
thanks, I just sent you a message via e-mail and anxiously await the installation procedure.  thanks
Posted: July 13 2010 at 21:54 | IP Logged Quote diveryates
Sorry Scuba, incorrect email address.
Should be:
diveryates@yahoo.com
best Roy
scubapop
Posted: July 14 2010 at 07:30 | IP Logged Quote scubapop
Guess I should have read the address rather than just copy and paste, oh well correction made and message resent.  thanks!!
scubapop
1975 express day cruiser 25
"OFF-COURSE-AGAIN"
boatman66
Posted: July 15 2010 at 09:31 | IP Logged Quote boatman66
SCUBA POP THE WINDSHIEL IS IN 4 SECTIONS AND IS QUITE BULKY WHEN REMOVING OR INSTALLING-I HAVE DONE MINE-THER ARE WIRES RUNNING UP THROUGH BOTH SIDES OF THE SIDE WINDOWS ONE SIDE IS ANCHOR LIGHT FEED-THE OTHER SIDE IS WIPER MOTOR WIRES-BE EXTREMELY CAREFUL WHEN DISASSEMBLING--THERE ARE SCREWS ALSO IN THE SIDE WINDOWS AND THE SECTIONS COME APART BY ROTATING THEM-- NOTICE THE ALUMINUM CHANNELS THEY ARE KEY TO THE WHOLE THING ONE IN THE CENTER AND ONE ON EACH CORNER-ALSO BE VERY CAREFUL OF THE WING VENTS-THEY ALSO ROTATE INTO POSITION AND IF NOT CAREFUL WILL SLIP AND FALL OUT--GOOD LUCK
1986 294 catalina twin 350's
scubapop
Posted: July 19 2010 at 07:27 | IP Logged Quote scubapop
thanks for the input will let you and Roy know how things turn out when the replaement arrives.
scubapop
"OFF-COURSE-AGAIN"
scubapop
Posted: August 07 2010 at 18:16 | IP Logged Quote scubapop
WINDSHIELD REMOVED AND INSTALEED I N 45 MINUTES----THANKS FOR ALL THE HINTS AND THE ORGINAL INSTRUCTIONS FROM ROY .
scubapop
"OFF-COURSE-AGAIN"
