Subject Topic: Cabin Door Post ReplyPost New Topic
jhawk
Posted: May 31 2010 at 19:54 | IP Logged Quote jhawk
I have a 2002 310.  The door is hard to slide.  I have cleaned and tried WD40 on the slides, top and bottom, but that only works toemporarily and it also makes a black substance on the bottom slide and if someone steps on it the black marks go wherever.  It looks like a major job to get that door removed to be able to put new slides or whatever to make it open easier.  Does anybody have any suggestions
jhawk
SW Florida
2002 310SE
Back to Top Printable version View jhawk's Profile Search for other posts by jhawk
INWATER
Posted: June 01 2010 at 02:43 | IP Logged Quote INWATER
Looking forward to an answer to this one. I have used silicon spray with same results.
Larry
Back to Top Printable version View INWATER's Profile Search for other posts by INWATER Visit INWATER's Homepage
bannister
Posted: June 23 2010 at 17:43 | IP Logged Quote bannister
actually slides on the 250SE came out easily without removing the door.
cleaned them good and WD40 did the job. it slides just fine.
a quick spray every month or so keeps it sliding every time.
To remove the slides, just move the door back and forth, undo the screws and use on hand to lift the door weight of the slide. then use the other hand to slowly remove the slide by.... sliding it out of place. they are plastic and will bend a bit if needed.
reverse procedure to finish....
Edited by bannister on June 23 2010 at 17:44
Back to Top Printable version View bannister's Profile Search for other posts by bannister
jhawk
Posted: June 24 2010 at 18:44 | IP Logged Quote jhawk
Thanks for the post Bannister.  I'll take a look at that and see if my slides will come out.
jhawk
SW Florida
2002 310SE
lexman
Posted: August 16 2010 at 22:27 | IP Logged Quote lexman
Clean out the tracks and rub down with a bar of soap- works great!!!
Back to Top Printable version View lexman's Profile Search for other posts by lexman
