Bayliner
Subject Topic: Oil in Bilge, Suggestions in Where to Lo Post ReplyPost New Topic
raulrio
Posted: May 31 2010 at 10:00 | IP Logged Quote raulrio
After taking run my 2004 265/5.7 Merc/Brvao 3 from winterized storage and going out for a run for about an hour, I noticed that there is new oil in the bilge.  I had cleaned the bilge prior to going in the water and running it, so I know it was clean.  I ran for about an hour, the engine oil level is just below the OK mark, and there is a three to four inch wide spill in the bilge.
Any suggesttions what I should look for and either try fix myself or tell the service department?
Thanks in Advance,
Raul
Back to Top Printable version View raulrio's Profile Search for other posts by raulrio
