Glastron
 BoatUS Boat Groups/Manufacturer Forums>>Glastron
Subject Topic: MX 175 Overheating Post ReplyPost New Topic
philrod
Posted: May 21 2010 at 22:47 | IP Logged Quote philrod
I have an MX 175 with the Volvo-Penta 3.0 GLP-C engine.  Last year I had to replace the raw water pump housing because the plastic had separated from the brass and it was sucking air and over heated.  It was replaced with the solid brass housing.  Since that problem, on the first start of the day the temperature will climb over 200 degrees until I rev the engine in neutral to about 4,000 RPM then it will settle between 150 - 175 degrees and be fine for the rest of the day.  I've changed the thermostat and impeller and still have the same issue.  Anyone have any ideas?
Edited by philrod on May 22 2010 at 11:05
MX 175 w/3.0 GLP-C
Back to Top Printable version View philrod's Profile Search for other posts by philrod
This page was generated in 1.1738 seconds.
