Subject Topic: 288 Adventurer Fuel Tank Post ReplyPost New Topic
adiver2b
Posted: April 06 2010 at 08:56 | IP Logged Quote adiver2b
Hi
Has anyone had to replace their fuel tanks, if so what with. I have a 288 Adventurer.
Back to Top Printable version View adiver2b's Profile Search for other posts by adiver2b
NO-OHMS
Posted: April 06 2010 at 09:58 | IP Logged Quote NO-OHMS
Hi, adiver2b
I have not replaced my fuel tanks but I have removed them from the boat . My tanks were starting to corrode and pit I sand blasted and used an aluminum based putty to coat the bottom half of the tank,then I coated the tanks with an epoxy coating.  I have not reinstalled the tanks yet but I will soon.  I am in the middle of a complete refit of the boat.  I hope to have the boat in the water next season.  I had thought of replacing the tanks.  My tanks are 100 gal.  I looked into plastic tanks but you have to be carefull with the larger tanks because they need to be baffled.  I did find replacement aluminum tanks ,they were around 700 to 900 dollars apiece so I went for repair rather than replace my tanks were pretty solid and had no leaks.
I hope this helps
Mark T
Edited by NO-OHMS on April 06 2010 at 10:00
M Tibbetts
NO-OHMS
Thompson 288
Back to Top Printable version View NO-OHMS's Profile Search for other posts by NO-OHMS
Don B
Posted: April 06 2010 at 11:22 | IP Logged Quote Don B
I have the removed the entire floor and inspected the tank real close.  I have a 60 gal that was actually in real good condition w/ no external corrosion.  If you look into replacing and consider plastic, be sure to get on that is compatible w/ "E" fuel.  we are all real gas now, but i have heard that places on the lake are switching.  Just a thought.
Don
"My Mistress"
'91 Thompson 255 Carara
Menasha, WI
Back to Top Printable version View Don B's Profile Search for other posts by Don B Visit Don B's Homepage
adiver2b
Posted: April 20 2010 at 08:17 | IP Logged Quote adiver2b
Hi
Thanks for the replies. After a close look I decided to go for the replacement option. There was just too big a risk in repair. The bottom was too badly corroded. The price that was mentioned sounds about right . I will let you all know how it all works out.
Marinebuoy
Posted: October 03 2011 at 12:29 | IP Logged Quote Marinebuoy
I have taken my 288 back to the hull from the head to the transom, engine stringers and everything out including the door system and even the floor, because as everybody knows Thompson built the bloody door right over the forward hatch The fuel tanks were perfect, and I'm wondering why yours are not. Maybe they were not of aluminum.
Incidentally, I turned the floor 180 degrees around so that now the door sits right on the beam that used to be 15" astern. All to help make the 'perfect boat'.
I went from 2 X 260hp Mercruisers to a single 6BT5.9 Cummins connected to a Volvo 290 Series Duo-Prop stern-drive. About this time last year joined this forum but life got in the way.
Marinebuoy
Back to Top Printable version View Marinebuoy's Profile Search for other posts by Marinebuoy
Posted: October 04 2011 at 06:13 | IP Logged Quote waterlogged
marinebuoy- i cannot wait to relive your project. did you get pics along the way?
This page was generated in 0.9883 seconds.
