C-Hawk
 BoatUS Boat Groups/Manufacturer Forums>>C-Hawk
Subject Topic: C-Hawk 25 DLX - Leaks Post ReplyPost New Topic
WDNEAL
Posted: March 25 2010 at 10:48 | IP Logged Quote WDNEAL
Okay - seems like I'm the first C Hawk owner to post, so just to get things started, I have a 1991 C Hawk 25 DLX powered by a 2007 Honda 225, mounted onto a 30" Armstrong extension. This boat did not come with a second helm amidship, so I added one behind the cabin. This is my second C Hawk 25. Hurricane Ernesto killed the first one.
The only issue I have with this boat is a persistent leak. After a day of fishing, I'll get about 1 to 2 quarts of water in the bilge. Cannot identify where it is coming from. While parked on a trailer last winter, I filled the hull with water and observed no leaks. I put a check valve on the bilge pump discharge hose. Checked the Armstrong extension bolts for leaks - none evident. If water was leaking in under the rub rail where the superstructure attaches to the hull, it seems I would see that from water running down the inside of the hull.
Any ideas on where else to look?
Virginia Reel
Back to Top Printable version View WDNEAL's Profile Search for other posts by WDNEAL
This page was generated in 0.9380 seconds.
