Bayliner
Subject Topic: Bayliner Cierra 2855 Engine Coupler Post ReplyPost New Topic
William H
Posted: March 18 2010 at 11:52 | IP Logged Quote William H
I have had to replace the engine coupler three times since 1999. Is this a Bayliner problem, a Mercruiser Bravo 2 problem or something I am doing that causes this? Thanks!
Edited by William H on March 18 2010 at 12:13
Bill
Back to Top Printable version View William H's Profile Search for other posts by William H
phess
Posted: March 18 2010 at 12:30 | IP Logged Quote phess
Engine size?
I have heard that some set ups are very critical on engine to drive alignment
Edited by phess on March 18 2010 at 12:33
Back to Top Printable version View phess's Profile Search for other posts by phess
William H
Posted: March 18 2010 at 13:56 | IP Logged Quote William H
350 7.4 L
Bill
donnalynnmike
Posted: August 01 2011 at 10:09 | IP Logged Quote donnalynnmike
I own a 1999 Bayliner 2855 with the 7.4L engine. I had to replace the engine coupler due to corrosion (not a fun job). The boat sat for about 2 years before I bought it. I did some extensive research and found that there are 2 critical issues with the coupler. One is lubrication and the other is drive alignment. Since you had to replace three times, I am assuming it is an alignment problem. I am not an expert or mechanic but my coupler has been fine since replacement in 2006. I lubricate it every year and properly aligned it back in 2006 (another fun job).
Back to Top Printable version View donnalynnmike's Profile Search for other posts by donnalynnmike
This page was generated in 0.8457 seconds.
