Subject Topic: shore water Post ReplyPost New Topic
oshawabob
Posted: January 23 2010 at 11:29 | IP Logged Quote oshawabob
When hooked up to shore water, the system backfills my water tank, and continues to pour out of the vent. So far, I have not investigated, but merely shut off the tap and continue to use boat pressure system. I am assuming that there is a valve or fitting to prevent continued backfilling of the tank? This Spring I would like to resolve this issue - any suggestions?
Cheers,
oshawabob
Chris Craft Catalina 381
M/Y Missy J
Back to Top Printable version View oshawabob's Profile Search for other posts by oshawabob
Banjoman
"First Mate"
Posted: January 23 2010 at 20:26 | IP Logged Quote Banjoman
oshawabob -  trace your city water fill line and look for a diverter valve which diverts water from your city supply to the tank.   It should be a 1/4 turn valve. My 381 had such a valve mounted in the engine room on the bulkhead. Many 381's had this valve installed from the factory.  This was set up so that when hooked up to city water,  you could simply fill your water tank while the hose was hooked to city supply. Pretty nice feature when it's pouring rain outside.  I liked it personally. Unfortunately, you have go in the engine room to divert the water.
I have surveyed a couple of other boats that the owners have installed this type of set-up but with the valve in the galley area.  Some folks like to run off their tank to keep it fresh.  With this valve, you don't have to keep removing the water fill, get the hose out and fill the tank.
CAUTION: Always remember to turn off the city water supply when you leave your boat!!
Hope this helps.
Capt. G. Emory Shover
m/v "SOUTHERN CHARM"
Eastern Marine Services, LLC
www.easternmarineservices.com
oshawabob
Posted: January 27 2010 at 17:35 | IP Logged Quote oshawabob
Thanks, Emory, I will follow your advice. I do have a pressure reduction valve that will be cleaned once Spring hits, the diverter valve - I'm not sure if it is there, but I think it might be.
What's your view of using grey plastic lines instead of copper f I want to lay new pipe?
Cheers,
oshawabob
M/Y Missy J
tomconfusion
Posted: May 02 2011 at 02:04 | IP Logged Quote tomconfusion
Hello oshawabob
Notes from my experience which may be helpful:
When we purchased the wife's 381, it had no shore water connection, the tank being the only freshwater source. As the wife planned to stay on the boat 3 or 4 days a week, we had the local marina plumb in a shore water connection which they TEE'ed into the main water line downstream from the fresh water pump. Even with a pressure regulator (which have been known to fail; 1 out of 2 so far) on the shore water intake line, I did not want the pump or tank to see much more than gravity pressure so I installed a check valve immediately downstream of the fresh water pump for the on-board water system. This prevents any pressure from the shore water system from reaching the pump, tank, or any other parts of the system upstream from the check valve.
As the shore water connection was not installed by CC, neither was the diverter valve noted by Captain Shover; I am going to look into that as the shore water outlets freeze from time to time during the winter around here.
Hope this is of some help.
???tom
Maintenance Officer
1984 381 Catalina
Back to Top Printable version View tomconfusion's Profile Search for other posts by tomconfusion
