Subject Topic: 1997 300 SC FUEL TANK LEAK Post ReplyPost New Topic
jjdoral
Posted: November 05 2009 at 10:28 | IP Logged Quote jjdoral
Need some help with this repair. Recently pulled my boat out of the water to be layed up for the winter. After a couple of days I noticed fuel coming out of the drain plug. After invstigated the source of the leak it appeared to be coming from the bottom or side of the fuel tank which is not visible. My marina has removed the fuel and is contimplating how to change the tank.
Doral tech services initially told me the tank can be changed through the aft cabin but after asking some questions, they called me back and said the engines must be pulled and the tank removed from the engine compartment! I don't have alot of confidence in what I'm hearing.
Anyone out there have any experience with similar problems or experiences?
jjdoral
Back to Top Printable version View jjdoral's Profile Search for other posts by jjdoral
This page was generated in 8.7656 seconds.
