Chaparral
 BoatUS Boat Groups/Manufacturer Forums>>Chaparral
Subject Topic: Gas tank failure Post ReplyPost New Topic
Kathie
Posted: October 02 2009 at 19:26 | IP Logged Quote Kathie
Has anyone experienced gas tank corrosion in their boat leading to holes, and leaking gasoline into the buildge?
We have, and recently learned that on the 1999 Signature 300, the gas tank is designed to actually sit too far into the buildge, thus causing tank corrosion along the bottom of the tank. The buildge pump works fine, but the tank is placed too far below the water line of the buildge.
Needless to say it's a VERY dangerous situation. If you have this year and model, please be careful. We are lucky we didn't blow-up!
We are having to have the gas tank completely remade and reconfigured so it will no longer hang under the buildge water line.
What on Earth was Chaparrel thinking?
Back to Top Printable version View Kathie's Profile Search for other posts by Kathie
chantillycpl
Posted: October 06 2009 at 07:31 | IP Logged Quote chantillycpl
Kathie,
You should be able to find what you need in the Chaparral Owners Forum.  They have some very knowledgeable members.  http://forum.chaparralboats.com/index.php?showforum=7
All Hanz On Deck
Chaparral Signature 310
Belmont Bay, VA
Back to Top Printable version View chantillycpl's Profile Search for other posts by chantillycpl
