Subject Topic: trim tab pump resivouir Post ReplyPost New Topic
bilge rat
Posted: August 30 2009 at 10:54 | IP Logged Quote bilge rat
my lady friend owns a 93 300 dancer. the trim tabs stoped working. i can hear the pump running when i use the tab switches it sounds like its behind the engines on transome. but i have been unable to locate the resevoir. does anyone no where this is located
Back to Top Printable version View bilge rat's Profile Search for other posts by bilge rat
moose
Posted: August 31 2009 at 18:49 | IP Logged Quote moose
nice to have a lady friend with a nice boat! Seriously, the trim tab reservoir is located on the transom. Sometimes hard to see but it is there. Sounds like fluid is low or empty. Open engine hatch, and have lady friend activate while you are in there listening. You should be able to locate that way. Some are hard to reach to open and fill.
Mutual Fun Too 26 Dancer
Back to Top Printable version View moose's Profile Search for other posts by moose
Don B
Posted: September 02 2009 at 09:32 | IP Logged Quote Don B
the unit, if Bennit, is about 4 x 8 x 8 high, not really ythat big.  Otherwise, find the 1/4 BLACK Poly tube comming thru the transom from the actuator cylinder and follow it back.
Good Luck, they like to fit small parts in smaller spaces!
Don
"My Mistress"
'91 Thompson 255 Carara
Menasha, WI
Back to Top Printable version View Don B's Profile Search for other posts by Don B Visit Don B's Homepage
This page was generated in 2.9707 seconds.
