Subject Topic: Air conditioner Post ReplyPost New Topic
Kluri
Posted: August 25 2009 at 10:48 | IP Logged Quote Kluri
I have a water problem being caused by my Air conditioner.  In the back of the AC unit is a drain tube which goes underneath.  The drain is for the mail coil pan and does not drain so when I take off the water spills out of the pan and sets off the aft bilge.  There is always water in the aft cabin under the fresh water tank.
Two questions:
1.  Where does it go, to the shower pump?
2.  It is kinked at the hole going under the unit, does it drain off of gravity?
I have a 2003 310
Back to Top Printable version View Kluri's Profile Search for other posts by Kluri
Ernesto
Posted: August 25 2009 at 11:38 | IP Logged Quote Ernesto
In my 2004 Doral Intrigue, the a/c pan hose just drained into the bilge,
you could see the end of it in the middle portion of the aft bilge. Not an
ideal setup I guess. Since it's the same boat, I would assume yours is
the same, but you never know.
Kluri
Posted: August 25 2009 at 11:49 | IP Logged Quote Kluri
Actually there are two drains the one you describe is coming off the large drain pan.
The one I am referring to runs off the back of the AC unit and serves the small drain pan in front right underneath the radiator.  This pan generates a lot of condensation and will fill up while runing the AC for a couple of hours.
Doral 310
Posted: August 26 2009 at 09:59 | IP Logged Quote Doral 310
I had the same issue on our 310 which is an 03'.  The drain hose from the pan on my boat goes to the sump pump.  The problem that I had was that the hose would get an air bubble and the gravity flow was not strong enough to push through.  What I ended up doing was adding a "T" fitting in the hose where the air bubble would form and it acts like a vent.  THe water drains now with no problem.
I also noticed that when I filled up the water tank and if I left the hose to overflow , the water tank would leak out the top by one of the fittings and leak water in the bilge under the aft berth.
Back to Top Printable version View Doral 310's Profile Search for other posts by Doral 310
Kluri
Posted: August 26 2009 at 10:14 | IP Logged Quote Kluri
Did you put the t fitting underneath the stairs, in front of the shower pump?  Is the T fitting open at the top?
Doral 310
Posted: August 26 2009 at 10:25 | IP Logged Quote Doral 310
I put the fitting unnder floor by the seating.  If you take the panel off above the unit ( under the cushion) you shoud see the hose.  I was able to reach down and see the air bubble and that is where the fitting went.  The "T" is pointing up and is open.  The pan drains well now and i can hear the sump pump kick on through out the day.   Good luck.
Kluri
Posted: August 26 2009 at 10:35 | IP Logged Quote Kluri
My hose comes off the back of the unit and you only see about 6-7 inches then in goes underneath.  Is this the same on yours?
Mine is kinked as it goes thru the hole down underneath the floor.  I thought that may be part of the problem as well.  Unfortunately I have tried to unkink it without much luck
Doral 310
Posted: August 26 2009 at 10:43 | IP Logged Quote Doral 310
Its been a couple of years since I did it.  I will have a look this weekend and get back to you.
Doral 310
Posted: September 08 2009 at 12:52 | IP Logged Quote Doral 310
Sorry for the delay, just returned from 11 days of boatng. I removed the access panel that was under the seating and took a look.  I have 2 fittings that come from the back of the pan that have a hose attached.  The 2 hoses go to a "t" that connects to the drain line.  The drain line runs down the portside to under the floor.  Just where the hose goes under the floor is where I added my "T" as a vent.  I this helps you out.  I'm sure the kink is also giving you some added issues to the draining.
Kluri
Posted: September 10 2009 at 06:24 | IP Logged Quote Kluri
I appreciate you taking the time to look.  I am going to attempt to fix it this weekend!!
Doral 310
Posted: September 11 2009 at 10:54 | IP Logged Quote Doral 310
No problem,  I really did not have much to do while spending 11 days on the boat while on vacation.
