Subject Topic: fuse panel layout, 1983 25’ catalina Post ReplyPost New Topic
soundrunner
Posted: August 23 2009 at 16:42 | IP Logged Quote soundrunner
hello everybody,
My next challemgeis finding the values for the fuses in the panel of my 1983 25' catalina.
Any body know where to go, or know the values?
Thank you,
SR
William Stamm
Deep River, CT
Back to Top Printable version View soundrunner's Profile Search for other posts by soundrunner
Banjoman
"First Mate"
Posted: August 23 2009 at 22:12 | IP Logged Quote Banjoman
SR - you most likely will have to pull the panel and retrieve that specific info off the original breakers.  There is a label on the breakers that identify the breakers part number, voltage, etc.  Do not assume that an off-the-shelf breaker from West Marine will work on your panel.  There have been many changes since your boat was built.  If you need a replacement breaker, it is better to pull the old one and get the manufacturer's data.  This is especially true on the 12vdc side.  I had to replace a couple of breakers (and add a new service) on my 86' Chris Connie.  The breakers were manufactured by AirPax who is now Sensata Technologies  http://airpax.sensata.com/   They still carry all the breakers as far as I know.  Hope this helps.
Capt. G. Emory Shover
m/v "SOUTHERN CHARM"
Eastern Marine Services, LLC
www.easternmarineservices.com
soundrunner
Posted: August 24 2009 at 16:20 | IP Logged Quote soundrunner
banjoman,
Thanks. I need that info bad as well, but what i am looking for is the fuse  values for the fuses mounted under the switches at the helm.
I am going in order easiest to hardest...
Thank you much for the in fo.
SR
William Stamm
Deep River, CT
Nauti Cat
Posted: August 24 2009 at 16:30 | IP Logged Quote Nauti Cat
soundrunner,
I have a Catalina 280 and would imagine the fuse values would be similar (ones under each switch on the helm), I just need to look at the diagram.
The Mariners Museum in Newport News Virginia has most of the Chris Craft documentation including wiring diagrams for purchase which may help: http://www.mariner.org/library/chris-craft
Tom
Nauti Cat in NY
Formally owned by a
1985 Catalina 280
"MY WAY"
Nauti Cat
Posted: August 25 2009 at 13:55 | IP Logged Quote Nauti Cat
Soundrunner, here is what is listed on the schematic for the 280:
Key Ignition - 20A
Blower - 15A
Nav/Anc Lights - 15A
Panel Lights - 15A
Courtesy Lights - 5A
Bilge Pumps - 7.5A (each)
Wipers - 10A (each)
Horn - 15A
Trim Tabs (if equipped) - 20A
Good Luck,
Tom
Nauti Cat in NY
Formally owned by a
1985 Catalina 280
"MY WAY"
Nauti Cat
Posted: August 25 2009 at 13:59 | IP Logged Quote Nauti Cat
Soundrunner,
Should also note that if any of the components have been changed from the original spec (such as horn, pumps, etc.) you should probably check for that item's fuse requirements as well as wiring requirements.
For example, I upgraded my horn to a larger one and it had a higher amp fuse requirement but the wiring gauge was still within range.
Tom
Nauti Cat in NY
Formally owned by a
1985 Catalina 280
"MY WAY"
This page was generated in 1.1094 seconds.
