Subject Topic: No start, just clicking noise!? Post ReplyPost New Topic
soundrunner
Posted: August 22 2009 at 09:47 | IP Logged Quote soundrunner
Hello everyone.
trying to get in the water this season...ugh.
The boat only makes a click noise when i turn the key...starter? Any way to get a test and get a workaround so i can test motor while on land?
Thanks!
William Stamm
Deep River, CT
Back to Top Printable version View soundrunner's Profile Search for other posts by soundrunner
boatman66
Posted: August 22 2009 at 11:17 | IP Logged Quote boatman66
YEH FIRST CHECK BATTERY AND MAKE SURE IT IS FULLY CHARGED-SECOND HAVE A VOLTAGE TESTER WITH A TWELVE VOLT RANGE ON IT THIRD PUT TESTER ON POWER WIRE TO STARTER,THATS THE BIG FAT WIRE TURN KEY IF VOLTAGE TO THAT WIRE AND JUST STILL CLIKS,REMOVE STARTER AND GET IT FIXED..THERE IS THE SHORTEST ROUTE TO TAKE AS THERE ARE SO MANY COMPONENTS TO THE START SYSTEM THAT IF YOU ARE NOT MECHANICALLY/ELECTRICALLY INCLINED YOU COULD REALLY SCREW THINGS UP OTHER OPTION FIND A MECHANIC THAT KNOWS AND SHELL OUT THE BUCKS IT WILL BE CHEAPER IN THE LONG RUN BELIEVE ME GOOD LUCKTHIS IS MEANT TO HELP YOU NOT DENEGRATE YOU HOW IS CONN? WEATHER ANY BETTER THAN WHEN I WAS UP THERE IN JULY??
1986 294 catalina twin 350's
