Uniflite
Subject Topic: Wood in stringers? Post ReplyPost New Topic
Persistant
Posted: August 12 2009 at 13:06 | IP Logged Quote Persistant
The 1974? 28' Uniflite Sportfisher I am buying seems to me that Uniflite used foam as structure when they layed up the stringers.
Did Uniflite use any wood in the stringers, transom, or engine beds as part of their construction and structure?
28' Uniflite Sportsfisher
Back to Top Printable version View Persistant's Profile Search for other posts by Persistant
Oliver + Sharon
Posted: August 13 2009 at 13:46 | IP Logged Quote Oliver + Sharon
Got a 1971 31 Uniflite. So far the only spot I found some foam in the structure of the doors of the engine compartment. I had a fiberglass guy checking out the stringers and they are sound and for sure there is wood used in the construction.
Anyway to your other thread about blister. I read that all the problems with the blister started in 1975, but Uniflite used to produce the hull and had it sitting in the form until the next order for the same boat was in. Meaning the hull no. 189 might have gottin the superstructure later mabe even in the beginning of 1975.
Well, I wouldn't be to worried about this possibility if the boat has no signs of blisters @ this point.
Oliver
Back to Top Printable version View Oliver + Sharon's Profile Search for other posts by Oliver + Sharon
vintage 74
Posted: July 07 2010 at 20:12 | IP Logged Quote vintage 74
Hello, I own a 1974 36 Uniflite no wood use in the hull only foam in some ares.
Steve.
steve
Back to Top Printable version View vintage 74's Profile Search for other posts by vintage 74
