Subject Topic: 1975 Sea Ray Steering Post ReplyPost New Topic
tpc1964
Posted: July 29 2009 at 17:53 | IP Logged Quote tpc1964
Just purchased a 1975 Sea Ray SRV 240. It has original 351 Ford and has had the outdrive replaced with an alpha 1. Both run great. When excelerating or cruising at high RPM the steering pulls hard to the port. When idling or cruising slowly the steering is fine. Moves easily in both directions. I'm thinking it has to do with the prop torque but before I start messing with anything I wanted to see if anyone else has experienced this and what may have solved it. Any thoughts would be appreciated. Thanks
Old Sea Ray
Back to Top Printable version View tpc1964's Profile Search for other posts by tpc1964
