Subject Topic: Monticello porpoising Post ReplyPost New Topic
Mikesf
Posted: July 09 2009 at 22:08 | IP Logged Quote Mikesf
Lately my 2006 Monticello has started porpoising, even in relatively
calm water. Anybody have an idea what causes this? The drive is not
trimmed.
p5surf
Posted: July 10 2009 at 09:43 | IP Logged Quote p5surf
Porposing is common in all boating and usually indicates
that the thrust from the engine is not parallel to the line of
travel.   If your thrust is pointed downward, even by a slim
margin, it will cause the bow to ride up, conversely if the
thrust is pointed upward, the bow will dig in. Both
circumstances will cause porposing in different conditions.
The trick is to first (while motionless) create an even
distribution of weight around the boat. Next, once
underway, adjust the trim using the trim/tilt of the engine
settings, and then align the trim tabs (if equipped) to assist.
You may also want to check the bottom of your hull to be
sure there are no barnacles, etc... growing on the bottom.
Even a slight growth of alge can cause variation in your
planing.
Furthermore, if your boat is equipped with duel engines,
both engines must be trimmed in alignment.
I hope this helps get you started in your journey.
Safe boating!
p5surf
Back to Top Printable version View p5surf's Profile Search for other posts by p5surf
